Honda Motorcycle Forum
Honda Motorcycles
Navigation » Honda Motorcycles - FireBlades.org > General Motorcycling > General Discussion » need a how too on installing a ZENER DIODE on a 929rr
Old 01-23-2009, 10:07 PM   #1
chong74 is on a distinguished road
Hi in new to the forms but been reading.Im trying to install a 2001 929rr and the main harness in to a sandrail and i know i need a 3.9 volt zener to make it run. but no one has shown what color wire to put together . all i see is that the pink wire should be 9v .If any one can help buy a picture or a wire diagram that shows from where to where. also is there a wrong way to install one witch way does it go thanks for all your time and help...
chong74 is offline   Reply With Quote
Remove Ads
Old 01-24-2009, 4:58 PM   #2
MACI4LIFE will become famous soon enoughMACI4LIFE will become famous soon enough
Send a message via ICQ to MACI4LIFE
Re: need a how too on installing a ZENER DIODE on a 929rr
very confusing....
what exactly are you trying to do? i googled sandrail and all i see is a dune buggy sorta thing. are you trying to install a 929 engine into a sandrail and are using the 929 wiring harness along with the install ( and want to amalgamate the 2??)
MACI4LIFE is offline   Reply With Quote
Old 01-30-2009, 7:52 PM   #3
yes sorry i have a small sand rail a 800cc B.M.S sandrail. and i wont to remove th stock motor and replace it with a 929 motor.i have the main harness to use to install this motor in to the sandrail all i need is to know how to bypass the pink wire on the ignition with a ZENER DIODE thanks for looking
Search tags for this page
cbr600 diode
honda fit zener diode
honda fit zener diode location
how to install a zener diode
how to install zener diode
how to wire a zener diode
how to wire zener diode
install zener diode
installing a zener diode
picture honda fit zener diode
zener diode install
zener diode installation
You may not post new threads
You may not post replies
Installing New ECU / ICM ami422 Honda CBR 600 0 09-13-2008 3:38 PM
Installing new ECU / ICM ami422 Honda FireBlade 0 09-13-2008 3:36 PM
Installing Alarm system on 01' 929rr aeroworks Honda FireBlade 1 02-14-2006 4:40 AM
installing PC3 jerseydrew Honda FireBlade 8 07-17-2003 4:13 PM
Installing a new chain ER Honda FireBlade 1 06-26-2003 9:29 PM
