Honda Motorcycle Forum
Honda Motorcycles
Navigation » Honda Motorcycles - FireBlades.org > General Motorcycling > General Discussion » how to remove the airbox and install new throttle cable line
Old 05-28-2009, 8:52 PM   #1
ty929 is on a distinguished road
Send a message via AIM to ty929
I am trying to remove my airbox on my 929 can anyone walk me through it and after that I am trying to instal the ne wthrottle cables I just got. And if there is anything I need to know before I take on this task... thanks to all....
ty929 is offline   Reply With Quote
Remove Ads
Old 05-28-2009, 9:14 PM   #2
Reputation Power: 179
bladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond reputebladeracer has a reputation beyond repute
Re: how to remove the airbox and install new throttle cable line
Prop the tank up and remove the screws from the airbox lid (you'll need a long phillips screwdriver). Remove the filter and the screws in the velocity stacks. If you want to completely remove the airbox you'll have to disconnect the flapper cable and some hoses.
If you planned to remove the PAIR system or flapper this would be the time to do it.
And while you have the tank up pull the vacuum hose off the fuel pressure regulator and make sure it's dry.
bladeracer is offline   Reply With Quote
Old 05-28-2009, 10:50 PM   #3
Thanks for telling me I will be on it in the morning..why would I want to remove the pair system and flapper does that give me more power or something?.... ok my second question is how to install my new throttle cable wires.
Old 05-28-2009, 11:03 PM   #4
You have to disconnect the PAIR system if you are tuning via the air/fuel ratio as it puts fresh air into the exhaust gas. I removed mine for this reason as well as to reduce weight and improve airflow over the engine.
The flapper is just a pointless gadget that many people remove.
Removing either won't give you more power.
It's a bit complicated to write it out.
Don't you have a manual?
You may find it useful to take a bunch of photos of the routing of the cables and the positions of the adjusters before disassembly.
Basically loosen off all the adjusters at both ends of the cables, remove the switch gear from the handle bar and disconnect the cables from the twist grip and throttle bodies.
Install the new cables the same way.
Adjust the pull cable first so it has a little freeplay to ensure the throttle plates fully close and then adjust the push cable to take up any further slack.
It can be a real pain hooking them onto the throttle bodies so you may need three hands, good light and some long-nosed pliers. I wouldn't recommend doing it if you've had a bad day or there could be lots of cursing ;-)
Old 05-28-2009, 11:12 PM   #5
CBR929RE's Avatar
Images: 24
Reputation Power: 33
CBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud ofCBR929RE has much to be proud of
long needle nose pliers are a must and I also used one of those little pick hooks. I got these Craftsman 4 pc. Pick Set - Model CHP4-L at Craftsman.com
its like you need 3 hands but you need your fingers to be spaghetti sized.
CBR929RE is offline   Reply With Quote
Old 05-28-2009, 11:15 PM   #6
Thanks I. will remove the flapper and the pair system..thanks for the advice I will let my hsop do my cables, hey bro anything else I can do that would help my bike, like removing th pair system, my bike is stock besides a k@n filter. Any tricks you got...
Old 05-28-2009, 11:19 PM   #7
When it's time for a new filter get rid of the K&N and use an OEM or BMC.
If you remove the PAIR you will need to cap the ports on the valve cover or make some plates to cover the holes.
Old 06-16-2009, 6:47 PM   #8
How much play should you have in the throttle
Old 06-16-2009, 6:49 PM   #9
Just enough to prevent it from binding - perhaps 1-2mm.
Search tags for this page
01 gsxr throttle cable install
1983 honda xr100 throttle cable install
honda cbrf4 throttle cable installation
honda hornet airbox removal
how to attach throttle cables on 05 gsxr
how to install gsxr throttle cable
how to install throttle cable on 1983 honda big red
how to remove throttle on honda ct 70
how to replace throttle cable in a 07 gsxr
installing new throttle cable for honda ct70
replacing throttle cable 1994 honda
valkyrie throttle cable routing
You may not post new threads
You may not post replies
throttle cable help timmeh Honda CBR 600 6 07-10-2008 6:10 PM
Throttle cable help pmpaluda Honda Naked Sportbikes 3 05-28-2008 10:30 AM
Throttle Cable Godti Honda FireBlade 7 03-01-2008 12:45 PM
954 Throttle Cable DUX Honda FireBlade 3 06-06-2005 12:51 AM
