05 Rep1000rr bogging out at 8000 rpm's - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 05-29-2010, 3:30 PM Thread Starter
Hello all,
I have a 05 Rep 1000rr with only 600 miles (purchased from a military guy with no time to ride) and it was in storage. Bike has a full Yoshi exhaust w/PC3. Bike starts, idles and runs fine.. BUT if the bike is in neutral and at idle it will bog out immediately if you crack the throttle to a hard rev. If you baby it, it revs up just fine and you can snap the throttle at any rpm without any hesitation. It's just at idle. The other problem is it bogs out at 8000 rpm's also. It has done this since day 1 even with the stock exhaust. It's in the shop and they're saying it's definitely a fuel issue. They're scratching theirs heads also. I know I'm reaching but could any of the injectors be bad, or does the ECM/ECU (computer) have any regulation of the fuel?
The reason I'm asking about the ECM/ECU is because this bike was originally in Japan and built to Japanese specs. Japan regulates their factory horse power to only 97hp for safety. They also block most of the air intake. I have since change out to U.S. air intake and air funnels (larger ports) but I'm still having the same bogging out that I had with the factory exhaust and air intake. The Bike also has the H.I.S.S. (Honda ignition security system) so changing to a U.S. EMC does not allow the bike to start at all.
If the ECM has anything to do (acting as a governor) with it at high speeds, what would cause it to bog at idle while in neutral ?
confused, any suggestions ?
Thanks all
bearcat283 is offline
post #2 of 3 Old 05-29-2010, 5:52 PM
Reputation Power: 7
Re: 05 Rep1000rr bogging out at 8000 rpm's
sounds like the fuel set up and carmalized. or there is a pinched fuel line. if the jap spec is the culprit i have an o4 ignition and lock set full wire harness and ecms in my part out and probly anything else you need
complete partout of 04 -07 cbr 1000rr
skip954 is offline
post #3 of 3 Old 05-30-2011, 11:07 AM
hi did you ever get the cuttig out problem solved
Originally Posted by bearcat283 View Post
Hello all,
hi did they ever fix the cutting out problem on your blade
Thanks all
bob2 is offline
Human Verification
Search tags for this page
04 cbr 1000 hesitation when full throttle
07 gsxr 1000 cuting out at high rpm but when clutched it revs fine
2007 gsxr wont max rpm
cbr 10007000 rpm bogs down?
cbr1000rr 04 cut off rpm at 8000
cbr1000rr bogs on low rpms
honda cbr1000rr 2006 does not rev above 10000
my 06 cbr1000rr wont rev pass 8000 rpm
why cbr1000rr jerking at 8000rpm
why is my 06cbr1000rr cutting out at 7000 rpms
Bad Bogging on 954 CBR954RToughnut General Discussion 11 03-21-2010 4:24 PM
Bogging down on 900rr 95erion Honda FireBlade 0 04-23-2009 11:54 AM
help bogging out rene-martinez Honda RC51 5 02-20-2009 1:18 PM
929 cuts out above 8000 RPMS onedownfiveup Honda FireBlade 13 05-01-2008 4:35 PM
Bogging in low RPMs sinfuldragon Honda CBR 600 7 06-15-2007 11:03 AM
