Fuel Pump issue, Plz help - Honda Motorcycles - FireBlades.org
post #1 of 5 Old 02-18-2011, 7:38 PM Thread Starter
Hey guys, It seems that I have run into a problem with my 1985 Honda shadow 700. My fuel pump will click on my initial key turn as a prime, but wont kick back on. I have changed the fuel lines, fuel filter, battery, cleaned the jets, and still no luck. The only way I have got it started is by turning the key on and off about 15 times to get gas to the floats, but while the bike is running it seems to not be pumping. I'm pretty new with bikes so I'm learning as I go. I took the fuel pump off and hotwired it to the battery and it does the same think. Clicks once, and when i drop the power it retracts. Is this how a fuel pump is supposed to work. Does the fuel pump relay turn power on and off to the pump in order for it to work? Please help me out. I'm totally out ideas.
Chris Medellin is offline
post #2 of 5 Old 02-18-2011, 8:26 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: Fuel Pump issue, Plz help
Sounds like you're talking about the relay rather than the pump.
The pump doesn't click.
Yes, that's what relays do. They just close the circuit to the pump.
The bike will run without the fuel pump at all as long as you keep the fuel level above the float bowls.
post #3 of 5 Old 02-18-2011, 10:58 PM
Location: Mostly Barbados,sometimes Florida & Western Canada
Images: 4
Reputation Power: 12
You need to perform a test on the pump itself while its hooked up to confirm voltage is going to it while in circuit on the bike.
If its anything like the points driven type of pump the early CBRs have, its possible the internal points are worn out. It will work erratically or not at all in this condition.
If you hook it up directly it should click constantly once its functioning correctly, if it has a cover on one end kept on with a screw remove it and look at the points faces.
These points move a lever within the pump body that drives the diaphragm internally to move the fuel through the system, its a low volume, low pressure pump.
900RR is offline
post #4 of 5 Old 02-19-2011, 6:48 PM Thread Starter
Thanks man, got a new fuel pump today. Worked like a charm.
post #5 of 5 Old 02-20-2011, 1:21 PM
Images: 4
There you go Chris, and now you can enjoy riding the bike.
900RR is offline
Human Verification
Search tags for this page
1985 honda shadow vt700c fuel pump how do you no when it's out
1987 honda shadow 700 fuel filter
fuel pump issues 1985 honda vt700c
fuel shut off valve for a 1984 honda vt700
honda shadow wont run without choke, bad fuel pump or relay?
how to chech fuel pump on a honda 700vt 1984
how to test a vt 700 shadow fuel pump
utube videos-1984 honda motorcycle-500-what is the voltage to the fuel pump
what fuel pump can go on a 84 honda shadow 700
where is fuel pump relay located on 1984 honda shadow 700c
954rr Fuel pump issue kawasakiklx Honda FireBlade 68 05-08-2015 8:24 PM
Fuel pump issue. Chris Medellin Honda Cruisers 2 02-26-2011 9:42 PM
929RR Fuel Pump Relay Issue WheelieGuy Honda FireBlade 7 11-02-2010 1:15 AM
Fuel pump issue? klayman Honda FireBlade 5 09-27-2006 8:03 PM
ARGH!#@#! Fuel Pump Issue victoRR Honda FireBlade 15 10-09-2004 2:57 PM
