R&G footrests - installation problems - Honda Motorcycles - FireBlades.org
post #1 of 3 Old 03-22-2012, 1:08 PM Thread Starter
Hello all,
I got R&G footrests for my R8. I installed the left one without any problems, but the right one is giving me grey hair.
I cannot figure out how to attach the ball bearing at the base of the brake cylinder so that the base assembly can be attached to the frame AND align the brake cylinder so that it can be screwed to the base assembly as well. To me it either looks like the hose from the brake cylinder to brake pads is too short, or I cannot screw the ball bearing deep enough ... have anyone had similar issues?
The other question is: how to attach the brake pedal spring that keeps the pedal up? And where to hook up the brake light switch? The instructions that came with the set are useless.
Hena
hena is offline
post #2 of 3 Old 03-22-2012, 1:26 PM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: R&G footrests - installation problems
Originally Posted by hena View Post
Hello all,
Hena
Without seeing it I can't guess what the problem might be. Do they state that the rearsets are designed to work with the OEM brake line?
Aftermarket rearsets generally don't come with provision for a brake light switch. You can put a pressure switch banjo bolt in though.
post #3 of 3 Old 03-22-2012, 1:37 PM
Reputation Power: 31
Send a message via Skype™ to 2WheelFury
Hello all,
Hena
Can you get us some pics? That would greatly help us to help you.
02 F4i track build-fully built motor, 600rr swinger and rear master, 1000rr front end and rear shock, akra full exh, pcIII and ign module, HRC radiator and quick throttle, brembo fr master and more
2WheelFury is offline
Human Verification
CCT Installation help for '01 929 flabre Honda FireBlade 2 07-01-2010 5:55 PM
CCT installation Fastrr Honda FireBlade 3 01-06-2007 3:46 PM
help with gilles footrests 9too9 Honda FireBlade 1 05-23-2006 5:32 AM
01 929 bar end installation help mbuckley Honda FireBlade 3 07-23-2004 12:45 PM
Servo Installation AfterShock Honda FireBlade 1 09-13-2003 5:19 PM
