XX Won't Hold a Charge - Honda Motorcycles - FireBlades.org
Honda CBR 1100XX Discussion of the Honda CBR 1100XX Super Blackbird Motorcycle.
post #1 of 9 Old 05-24-2006, 10:52 AM Thread Starter
southpark460's Avatar
Images: 3
Send a message via AIM to southpark460 Send a message via Yahoo to southpark460
Actually been riding a bit lately, and the other day my buddy went to start his XX and there wasn't enough juice to crank her over. So I pushed him and it bump started no problem. We rode about 5 miles down the road and stopped for food. An hour later she started up no problem. Yesterday (less than 24 hours later) no juice... The battery is maybe 2 months old. Bought it at the same time I bought the 7S for my RC. What else could it be? Regulator/rectifier? Stator?
southpark460 is offline
post #2 of 9 Old 05-24-2006, 11:00 AM
sheepofblue's Avatar
Images: 91
Reputation Power: 45
Re: XX Won't Hold a Charge
Sounds like a bad battery
You bump start it to get things going. It generates enough power to run AND start the bike later. Over night the battery discharges.
The only things I have seen cause this are a bad battery or short
Must obey the sheep dog
sheepofblue is offline
post #3 of 9 Old 05-24-2006, 5:37 PM
Reputation Power: 11
A loose cable can do that also. Check the plug between the stator and the Reg/rec also they melt and do strange stuff.
HRC NICK 11 is offline
post #4 of 9 Old 05-24-2006, 5:43 PM
Images: 3
Reputation Power: 12
Also check the terminals for corrosion- this can cause a 'dead' battery very easily.
redhotz28 is offline
post #5 of 9 Old 06-16-2006, 11:05 PM
Send a message via AIM to 2dealdrive
the rectifier is a know problem on the early ones, they upgraded in '99 I think it was and again 2 years later maybe?
Was the batter charged on the bench before going into service?
2dealdrive is offline
post #6 of 9 Old 06-19-2006, 10:40 PM
How many miles are on his bike? The regulator/rectifiers seem to go bad around 20,000...
Mine went out at 22k. It comes on fast; all of a sudden you discover your bike won't crank over. Then it's fine... no worries. Next day, starts up fine you ride somewhere and shut it off. No juice. If you get it started -- bump start or with a jump -- you'll eventually find that the electrial instruments (tach, gas gauge, temp) start flaking and eventually the bike will die because it's been running off the battery, not current from the stator.
dosequis driver is offline
post #7 of 9 Old 06-19-2006, 11:32 PM
Check the voltage at the battery while the engine is running. If it's over like 14.4 volts(I think) then it's the rectifier, and the bat is over charging. If it's less than 14.4, then it's the generator. If it's right around 14.4 or so, then you have a short circuit somewhere. A hot wire is getting grounded out somewhere on the bike. I've had a lot of problems with my f3... I assume a lot of properties apply
Nicky66 is offline
post #8 of 9 Old 10-22-2006, 3:43 AM
Check main fuse! i had same problem and quick fix was cleaning mainfuse connector.
westerholm is offline
post #9 of 9 Old 10-22-2006, 1:37 PM
Check out this post from the XX forum...
Dead Battery? - Public Discussion Forums
Also, trouble shooting flowchart from ElectroSport is helpful.
https://www.electrosport.com/electro...t_finding.html
And the Service Manual has an excellent step by step guide with all the XX specific values for each check. Last time I had similar problems, all the components checked out except that the battery was marginal, but still passed it's tests. It wasn't untill I pulled it and put a meter on it (after a full charge) overnight did it indicate that the battery was toast. Gotta new DieHard in it now and all is well (knocks on wood).
RayK
r2t2 is offline
Go Back   Honda Motorcycles - FireBlades.org > Honda Motorcycle Models > Honda CBR 1100XX
Human Verification
Search tags for this page
honda motorcycle won't hold a charge
how do i fix my suzuki gs500 fr whenbit wont keepba charge
motorcycle battery won't charge
motorcycle battery won't hold a charge
motorcycle battery won't hold charge
motorcycle battery wont charge
motorcycle battery wont hold charge
motorcycle wont hold a charge
my motorcycle battery wont hold a charge
why wont my motorcycle battery hold a charge
bike wont hold a charge Archer CBR 900R Honda FireBlade 13 10-23-2006 2:24 PM
Music on hold ND4SPD Off-Topic 20 02-22-2006 9:39 AM
Chain hold yourself back! EDDIE110171 General Discussion 9 04-20-2005 11:05 PM
texas hold em bubba Off-Topic 21 10-22-2004 1:48 PM
Charge or replace? nomad General Discussion 16 05-26-2004 3:05 AM
