11-10-2006, 6:03 PM
Bike(s): 2003 Honda CBR1100xx Posts: 5
| 03 CBR1100xx Problem I have a 2003 CBR1100xx which I just purchased about a month ago. When I purchased the bike, the battery was bad. I replaced the battery and am having a problem with the bike not changing the battery. The bike will work for a couple of days and then I will try to start it and the battery will be dead. I purchased an OEM battery from the Honda dealer. When the bike is running, it changes arround 12.5-12.9 volts when the battery is fully changed. The other night, I went throught the service manual and went through the troubleshooting flow chart, and did the resistance test on the stator and it is within specs about .3 OHMS. and I checked the connectors on the rectifier/regulator and they check out fine. Durring my test I (of course) had to disconnect the RR, when I connected the RR backup I again checked the charging voltage and it was from 13 volts to 14.4 volts as I reved the engine. I rode the bike for a day or so and decided to check the battery voltage, noticed it was about 12.4 volts, checked the charging voltage and it was back to 12.6 volts, so I am not sure if it is the stator or the RR that is bad. Any advice will be appreciated. Thanks |
11-11-2006, 12:15 AM
#2 | | Doorbell broke, please sound fog horn!
Bike(s): 06 FJR1300 Posts: 1,243
| Re: 03 CBR1100xx Problem
I think it sounds like the reg/rect. Have you checked all fuses, etc?
Have you checked prices on the RR? |
11-11-2006, 12:24 AM
| Re: 03 CBR1100xx Problem I figured it was the RR, The dealer wants $133.99 |
11-11-2006, 12:30 AM
#4 | | Doorbell broke, please sound fog horn!
| Re: 03 CBR1100xx Problem Makes it a bit of a commitment at that price. My son's Triumph had similar issues, turned out to be the RR.
Have you checked ebay? |
11-11-2006, 12:43 AM
| Re: 03 CBR1100xx Problem yes, ebay has a used one for $100. Think it might be better to spend the extra $33. |
11-11-2006, 12:51 AM
#6 | | Doorbell broke, please sound fog horn!
| Re: 03 CBR1100xx Problem Quote:
Originally Posted by kev7xx yes, ebay has a used one for $100. Think it might be better to spend the extra $33. | Yes, definitely!  |
11-11-2006, 12:57 AM
Bike(s): A few Posts: 1,000
| Re: 03 CBR1100xx Problem |
11-11-2006, 1:09 AM
| Re: 03 CBR1100xx Problem Thanks |
11-11-2006, 1:15 AM
#9 | | Doorbell broke, please sound fog horn!
| Re: 03 CBR1100xx Problem It is possible to get some good advice on here!
Hope you enjoy the Blackbird! I had a 2000 and really liked it. In fact, I may get it back  . |
11-26-2006, 10:26 AM
Bike(s): CBR1100XX Posts: 3
| Re: 03 CBR1100xx Problem Before buying any spares, Check and clean main (and other) fuse(s)  ... I had similar problem, but it was fixed by cleaning fuces  |
12-29-2006, 8:50 PM
Bike(s): 2003 honda cbr 1100xx Posts: 5
Originally Posted by kev7xx I have a 2003 CBR1100xx which I just purchased about a month ago. When I purchased the bike, the battery was bad. I replaced the battery and am having a problem with the bike not changing the battery. Thanks | Where are you parking the bike after you ride it? If its on a concrete slab - you need to get yourself some rubber mats underneath or some stands and get the wheels off the concrete. I had a similar problem and thats what worked for me- |
09-07-2007, 2:31 PM
Bike(s): honda cb650, 02 cbr 954, 94 fzr 600, 98 cr250 Posts: 149
Rep:  (13) Rep Power: 3
| Re: 03 CBR1100xx Problem wtf? How does parking on concrete and a bad regulator have anything in common? |
09-12-2007, 2:02 AM
#13 |
| Re: 03 CBR1100xx Problem no idea kris- but it solved the problem- don't ask me how. |
03-16-2008, 12:29 PM
#14 |
Bike(s): 2003 CBR1100XX Posts: 1
| Re: 03 CBR1100xx Problem I got this bike last yearl and the oddometer is in miles/hours..... I life is montreal, Canada and i need it be in Km/h. I don't have the manuals for the bike. Does any one knows how can I change the digital oddometer to Km/h...
please. |
05-22-2008, 8:04 AM
#15 |
Bike(s): 2003 Red Honda CBR 1100 XX Super Blackbird Posts: 3
Originally Posted by kev7xx I have a 2003 CBR1100xx which I just purchased about a month ago. When I purchased the bike, the battery was bad. I replaced the battery and am having a problem with the bike not changing the battery. The bike will work for a couple of days and then I will try to start it and the battery will be dead...... | I got the exact same problem on my '03 xx.
I took the bike to Honda service and they said there is no probs what so ever.
How did you manage to solve the problem.
Did you change the RR ?? or was it the fuses???
cheers. |
05-28-2008, 7:39 AM
#16 |
Bike(s): Had about 14 over time, currently a CBR600F (1990) Posts: 2
| Re: 03 CBR1100xx Problem I think I read else where recently - since I am thinking about buying a CB1000, that the 2003 model had a generator coli overheating problem, which you might like to investigate further. I have tried to re find the page unsucessfully, but chances are it could have been within this forum. |
07-02-2008, 6:53 PM
#17 |
Bike(s): 1999 Honda CBR 1100XX Posts: 8
| Re: 03 CBR1100xx Problem The 1996 (I think) Yamaha R1 R/R is a direct plug in for the blackbird. I did that on my 99 when the R/R went out. Paid $26 bucks for it on ebay. search the CBR1100XX Owners Organization Portal site and you'll find the right model year and how to guides. |
