leaking gas - Honda Motorcycles - FireBlades.org
post #1 of 19 Old 06-14-2013, 3:43 PM Thread Starter
leaking gas
hello,
I filled my tank on my cbr 600 f2 and came back two days later the tank was empty. no gas on floor, so I am assuming the gas leak down into the crankcase. what could be causing this to happen? do anyone have any ideals?
lilmilt1969 is offline
post #2 of 19 Old 06-14-2013, 5:40 PM
Images: 1
Reputation Power: 30
Re: leaking gas
More than likely, you've got one or more stuck floats in your carbs - you can usually give a firm "rapping" with a ratchet handle or something of the like, to the fuel bowls, to "free up" the stuck floats, but if it recurs, you'll need to pull the carbs to clean/inspect at least the bowls/floats/float needles/etc.
Since you might not be aware of the danger, be sure to NOT try to start the motor, as you could get a hydro-lock condition in one or more cylinders, and cause damage - if I were you, I would pull all your plugs, and turn the motor over either manually, or with the starter, while the kill switch is engaged, to eliminate the risk of the hydro-lock.
Gas does eventually evaporate, and somewhat quickly, pending the conditions, but if you really have a whole tank worth of gas in there, even without reserve, you might have soaked your muffler packing with gasoline as well... it might be advisable to remove the muffler, drain it, and let it sit somewhere where the gas will evaporate away, or you might have a heck of a fiery situation in your can!
JNSRacing is offline
post #3 of 19 Old 06-15-2013, 12:16 AM
Images: 2
Quoted: 2 Post(s)
Reputation Power: 227
Re: leaking gas
Originally Posted by lilmilt1969 View Post
hello,
Failed diaphram in a vacuum-operated fuel tap, or the float valves aren't sealing (or float heights are set too low).
post #4 of 19 Old 06-15-2013, 12:31 AM
Quoted: 3 Post(s)
Reputation Power: 23
Re: leaking gas
Don't forget to check your oil and change it if the level has come up (from adding gas to it)
ghbzorro is online now
post #5 of 19 Old 10-02-2013, 11:50 PM Thread Starter
Re: leaking gas
Well I have replaced fuel diaphragm,new plugs and bikke will not start now. The bike is turning strong. Do not know what to do now
post #6 of 19 Old 10-03-2013, 12:37 AM
Images: 2
Quoted: 2 Post(s)
Re: leaking gas
Do you have spark at the plugs?
Is there fuel in the float bowls?
post #7 of 19 Old 10-04-2013, 1:11 PM Thread Starter
Re: leaking gas
yes, I am getting spark and gas at the bowl. I see some gas dripping from the bottom of the carbs.
post #8 of 19 Old 10-04-2013, 1:16 PM
Images: 2
Quoted: 2 Post(s)
Re: leaking gas
The carbs definately should not be leaking. You did already rebuild them right?
Clamp the vacuum and fuel hoses to stop fuel flow, drain the float bowls, then try firing her on starter fluid.
post #9 of 19 Old 10-04-2013, 4:10 PM Thread Starter
Re: leaking gas
k, but I need to rebuilt the carbs? that will stop the leaking? why are they leaking?
post #10 of 19 Old 10-04-2013, 5:00 PM
Images: 1
Re: leaking gas
Blade just asked if you already rebuilt the carbs, not recommended doing so, necessarily... I think the point of his question, was to inquire about the condition of the float bowl seals, and float needle valve seats, since, had you already rebuilt them, you would know if these items were not "up to snuff".
Not being there, working on the bike ourselves, we can't tell you why they leaking, for certain, but usual suspects would be: bad float bowl gaskets, stuck float needle valves (this usually causes fuel to leak into the engine), or the T-joints and/or O-Rings that seal them, that distribute the fuel from the main line, to the individual carbs... one T-joint goes to 1 & 2, and the other goes to 3 & 4.
post #11 of 19 Old 10-04-2013, 9:17 PM
Images: 2
Quoted: 2 Post(s)
Re: leaking gas
We already explained this which is why I asked if you'd already addressed it.
The float valves are leaking, either because they're worn or dirty or because the float heights are not correct.
post #12 of 19 Old 05-22-2014, 10:55 AM Thread Starter
Re: leaking gas
Hello,
I have done all the things listed above, but now I have another question about the fuel tank. if I remove my tank and turn on the fuel, should fuel run out of the tank? i am not getting fuel running out of the tank. please advise.
post #13 of 19 Old 05-22-2014, 7:36 PM
Images: 2
Quoted: 2 Post(s)
Re: leaking gas
Hello,
Yes, unless you have a vacuum-operated fuel tap. If you have then it should have a "prime" position which holds the diaphram open. Otherwise you will need to suck on the vacuum port to open the diaphram.
post #14 of 19 Old 09-15-2015, 2:42 PM Thread Starter
Re: leaking gas
Hello,
I noticed the other day that gas was coming out of the fuel vacuum tube connected to the #1 carb. is this normal? i am still having issue with the flow of gas coming from tank. I have 94 cbr 600 f2. please advise.
post #15 of 19 Old 09-16-2015, 9:39 AM Thread Starter
Re: leaking gas
Can I remove the diaphragm from the fuel petcock? maybe that will let the fuel come out of the tank. please advise.
Human Verification
Help? Something Leaking GotZoom General Discussion 1 07-20-2012 7:18 PM
oil leaking slamv33 Honda CBR400RR 2 07-09-2012 1:38 PM
oil leaking? Marc954rr General Discussion 5 07-25-2010 6:42 PM
02 954 leaking gas Moldymonte Honda FireBlade 5 06-24-2008 4:23 PM
leaking oil on my 954 gumby Honda FireBlade 6 11-16-2004 1:43 AM
