Help!!!
Old 04-06-2004, 12:58 AM
NinerPilot's Avatar
Bike(s): 01 929
Help!!!
Ok,
Today I went and did some pre season work on DWC's F4i racebike. Now the damn FI light is on. Here is what I did:
*Replaced the Spark Plugs - Plugs I took out were Denso Iridiums and the Parts guy (which is very knowledgeable and a fellow racer) showed CR9EH-9's on the fiche and we got those. Can you replace Iridiums with standards... As of now, Iridiums will be on order tomorrow.
*Refilled with water/wetter This cant cause any difference.
*Replaced the cam chain tensioner.
The only thing I can think of is that I left a cable unplugged when re-assembling it. Or that the spark plugs make that big of a difference. The bike also smokes a bit now, which I dont understand either. It is a white smoke that comes out when under power. The FI light doesnt come on immediately and doesnt flash it just stays on. I took the tank and airbox off to get to the plugs and to the tensioner. Im currently looking through the repair manual now for a solution, with no luck so far.
Anyone have any thoughts.
Chris
NinerPilot is offline
Old 04-06-2004, 1:32 AM
Bike(s): '05 1000RR, '00 Mito 125, '99 F4, '03 GSXR 1k
Rep: RacerCutie is on a distinguished road (11)
Send a message via Yahoo to RacerCutie
Re: Help!!!
Iridiums are fine. That's what's on my bike. Check all the cable connections? Did you take the fuel tank/airbox off? There's a number of connectors there, check those?
When the FI light flashes, I think there's a code you can refer to in the manual (certain number of flashes in a certain sequence...).
RacerCutie is offline
View RacerCutie's Profile View RacerCutie's Gallery Find More Posts by RacerCutie
Old 04-06-2004, 1:37 AM
NinerPilot's Avatar
Bike(s): 01 929
Re: Help!!!
It doesnt flash at all, just stares at me, and I took the tank and airbox off, but Im pretty sure I hooked it all back up.
Chris
Old 04-06-2004, 1:42 AM
NinerPilot's Avatar
Bike(s): 01 929
Re: Help!!!
Just found out that the side stand has to be down to use the codes, so Ill have to take the Jumper off the switch since there isnt even a stand on it.
Chris
Old 04-06-2004, 6:42 AM
Zeeman's Avatar
Bike(s): Black/Red 954, 136.3hp bone stock
Rep: Zeeman has a spectacular aura aboutZeeman has a spectacular aura about (155)
Re: Help!!!
Similar thing happened on my 954 when I did the pair mod. Forgot to plug the "map sensor" plug into the socket on the right side of the airbox. Lift the tank and have a look, don't even need to open up the airbox
Z...
Zeeman is offline
View Zeeman's Profile View Zeeman's Gallery Find More Posts by Zeeman
Old 04-06-2004, 9:11 AM
ND4SPD's Avatar
Bike(s): '84 Magna V30
Re: Help!!!
When was the last time the bike ran before you did all this work? Did it have gas preservative?
ND4SPD is offline
Old 04-06-2004, 3:32 PM
NinerPilot's Avatar
Bike(s): 01 929
Re: Help!!!
Bike ran an hour before hand flawlessly. Then I let it cool to replace the plugs.
Chris
Old 04-08-2004, 11:20 PM
Re: Help!!!
Chris,
Did you ever find the problem?
Old 04-09-2004, 1:23 AM
NinerPilot's Avatar
Bike(s): 01 929
Re: Help!!!
Yeah,
Turns out we left the vaccum hose that connects to the bottom of the MAP sensor unplugged. It had fallen down against the frame and where it plugs in to the sensor is almost impossible to see. Problem is solved!!!
Chris
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:06 AM.
