cbr600f2 charging - Honda Motorcycles - FireBlades.org
 1Likes
  • 1 Post By Corvus
post #1 of 4 Old 03-16-2017, 10:24 AM Thread Starter
cbr600f2 charging
So I pulled out my cbr earlier this week for the first ride of the year. she started fine and ran fine, but about 7-10 miles down the road she started acting up: boggy revving up, wanted to die at idle. The next mile or so it got worse, I had to hold the revs at 3k-5k to keep it running made it all the way home and checked the battery; 8.5 volts. so I throw my 2 amp agm charger on it and it won’t take a charge. so yesterday evening I get a new battery and start her up, everything is going great and I run that same 10 miles. then this morning I take the bike to school and about halfway there I notice the blinker isn't working right, then it does the same thing: sputters at low rpm and finally shuts off.
now for the weird part; yesterday after I put the new battery in I started it to make sure it was charging. at idle I was getting ~14.5 volts at the battery. what could cause a brand new battery to die in less than 20 city miles and still get 14.5V
Joshp689 is offline
post #2 of 4 Old 03-16-2017, 11:57 AM
Quoted: 27 Post(s)
Re: cbr600f2 charging
What's the charge on the second battery after it died?
Sabotage is offline
post #3 of 4 Old 03-16-2017, 12:34 PM Thread Starter
I don't know I pushed it to the nearest parking lot and walked to class. After class, I'm going to get truck and haul it home then I can look at a few thing.
Joshp689 is offline
post #4 of 4 Old 03-17-2017, 7:39 PM
Bad regulator / rectifier is a strong possibility... a common fault on F2 and F3.
This is kinda a ton of info, but you could use this flow chart to ID the problem, if you have a multimeter:
https://www.electrosport.com/media/p...ng-diagram.pdf
Way back, I had similar issues and didn't solve the prob until I replaced with a known good R/R from an '03 GSXR750 (lots of model years should work). Basically, it's a higher quality and larger unit (better heat sink). I followed this wiring how-to:
My Own R/R Problem - CBR Forum - Enthusiast forums for Honda CBR Owners
Good luck!
Joe929 likes this.
Corvus is offline
Human Verification
CBR600F2 Hugger and Windscreen jondog9 For Sale 1 07-04-2012 10:26 PM
CBR600F2 parts maschutter General Discussion 3 12-18-2011 2:09 AM
CBR600F2 Upgrades maschutter General Discussion 34 11-20-2011 12:37 AM
Need Help With Cbr600f2 TRANS cosmo44 General Discussion 5 09-07-2008 8:22 PM
Help needed with a 91 cbr600F2 evo_prez Honda CBR 600 3 11-14-2007 5:43 PM
