Originally Posted by smirk43 2001 Honda f4i...Anyone ever had to deal with a flashing FI light. Everything was fine til' I installed a k&n air filter! I checked everything before I put the tank back on...but it will flash 9 times then blank for a few seconds, then flashes 9 times again!  Please help anybody...........thanks |
Could there be some sensor for air valve or something related air filter, can you try to remove it and double check that you have put everything back...
If this doesn't work contact local service, amount of flashes might give yoou some errrorcode
Hopefully you can fix it!
-C9B5R4-
