12-27-2005, 10:20 AM
#1 | | 2 up @ Grattan
Bike(s): 2005 600RR Age: 44 Posts: 1,555
| BRG 1/5 throttle install http://www.brgracing.com/throttle.html
What a PITA! Don't try this without a Dremmel or if you are a beginner. I wasn't sure $30 for a ring of plastic and 2 pages of instructions was worth it, but I guess you're paying for their R&D. Any way, after taking the airbox off, disconnecting the linkage from the throttle bodies, dissassembling and test assembling the throttle many times, and running out of daylight I finally completed the mod. It probably wouldn't have been such an issue for me, but most of my power tools, Dremmel included, were buried in a crate at the back of our garage.
To make the mod work you have to clearance the inside of the throttle housing to allow for the larger diameter cable spool. I tried it with a knife and needle nose pliers first, but after putting the throttle housing back together 3 times and still feeling major drag on the cable I dove in and dug out the dremmel. It works great now. But putting everything back together in the dark while holding a flashlite in your mouth sucks.  |
12-27-2005, 10:29 AM
Bike(s): 99 CBR1100XX (Street), 01 CBR1000RR (Track) Age: 41 Posts: 1,524
Rep:  (43) Rep Power: 7
| Re: BRG 1/5 throttle install But you needed the 1/5 throttle right? |
12-27-2005, 11:07 AM
#3 | | Send Maple Clarice
Bike(s): '04 CBR1000RR, '84 Ascot, '02 RC51 Posts: 13,813
| Re: BRG 1/5 throttle install |
12-27-2005, 11:31 AM
#4 | | Resident Cockhole
Bike(s): 2000 CBR929RR, 2001 RC51 Age: 32 Posts: 807
| Re: BRG 1/5 throttle install Quote: |
Originally Posted by sheepofblue | It's not much easier! I did mine 3 days ago. It requires a Dremel (or similar) too! But yeah, it was worth it...  |
12-27-2005, 11:54 AM
Bike(s): 2003 CBR600RR, 2003 CBR954RR Age: 29 Posts: 72
Rep:  (11) Rep Power: 4
| Re: BRG 1/5 throttle install this thread looks vaguely... familiar.... hehe.. yah im contemplating which kit to get for my RR as well.. |
12-27-2005, 12:07 PM
#6 | | Resident Cockhole
| Re: BRG 1/5 throttle install Get the HRC kit... Well worth the money. |
12-27-2005, 12:56 PM
#7 | | 2 up @ Grattan
Originally Posted by CBRBob But you needed the 1/5 throttle right? | Now that it's done I'm glad I did it.  |
12-27-2005, 10:02 PM
| Re: BRG 1/5 throttle install How about adding epoxy to the channel and readjusting the cables so you have a 1/5 throttle. I bet it would cost less than $5 and still look stock. |
12-27-2005, 11:03 PM
Originally Posted by CBRBob How about adding epoxy to the channel and readjusting the cables so you have a 1/5 throttle. I bet it would cost less than $5 and still look stock. | Wouldn't work for me.. I'm too impatient. I'd put it back together too early, and end up with a 0 turn throttle. |
12-28-2005, 9:20 AM
12-28-2005, 10:47 AM
Bike(s): Puch Posts: 14,391
Originally Posted by southpark460 Get the HRC kit... Well worth the money. |  Great resale value when you're done too.
I'll refrain from my true feelings on this thing.  |
12-28-2005, 12:24 PM
#12 | | 2 up @ Grattan
Originally Posted by CBRBob How about adding epoxy to the channel and readjusting the cables so you have a 1/5 throttle. I bet it would cost less than $5 and still look stock. | Better yet I could just pull one plug wire and use 3/4 the gas at full throttle. |
