05-03-2006, 11:49 PM
Bike(s): 2000 CBR 600F4------1999 Suzuki GSX-R600 Age: 30 Posts: 312
Rep:   (102) Rep Power: 4
| Clickety Clutch! The clutch on my 00' CBR 600 F4 makes a transmission clicking noise when the bike is in neutral and the clutch is free. I have read many of the older threads on this forum and it seem like this is pretty normal.
I wanted to ask if that were true and also ask why my clutch only grabs at the last second of being released.
Thanks,
Matt |
05-03-2006, 11:50 PM
#2 | | Resigned to pursue other interests.
| Re: Clickety Clutch! (Moved to CBR 600 Forum) |
05-03-2006, 11:53 PM
#3 | | Mr. Brownstone
| Re: Clickety Clutch! All clutches are a little noisy. Your cable is probably stretched and just needs to be adjusted. You can set the engage point anywhere you want, really as long as you leave a bit of slack for it to fully engage.
It may help with some of the noise as well. |
05-03-2006, 11:54 PM
| Re: Clickety Clutch! Thanks dude, I'll try it and let you know! I adjust it on the bottom end of the cable right? then adjust the slack on the lever knob? I wanna make sure I do it right.
Thanks,
Matt |
05-03-2006, 11:58 PM
#5 | | Mr. Brownstone
| Re: Clickety Clutch! Yep. Get most of the slack out down by the clutch cover, then fine adjust at the knob on the clutch lever.  |
05-06-2006, 3:31 PM
| Re: Clickety Clutch! Quote: |
Originally Posted by BDA116 Yep. Get most of the slack out down by the clutch cover, then fine adjust at the knob on the clutch lever.  | Thanks guys, it helped a ton.
Matt |
