tire removal
Old 05-05-2006, 12:08 AM
Bike(s): '03 954 rr, '03 600 rr track bike
Rep: KF810 is on a distinguished road (45)
tire removal
i'm going to the track this year and its finally time to do this myself.
i looked in the shop manual and for the front tire, it said to remove the fender, calipers, and to loosen and pinch bolts. and i was just wondering if all that stuff was really necessary just to take the axle out. and how much grease should i use on the axle for "reinsertion"
KF810 is offline
View KF810's Profile View KF810's Gallery Find More Posts by KF810
Old 05-05-2006, 2:03 AM
Re: tire removal
You shouldn't have to mess with the fender, but if you don't rempve the calipers you can't take off the wheel, since they're bolted inside the width of the rim.
Carefully hang them with wire or a bungee cord so they dont stress the brake lines.
You have to loosen the pinch bolts to remove the axle.
Now, when you put it all back together, use blue locktite and a torque wrench. Follow the recommendations in the book for torque values, and don't overtighten. Pay attention to the arrows on the wheel and tire.
I just spray the axle with WD or a light coat of white lithium grease. It doesn't take much.
CBRVFR is offline
Old 05-05-2006, 12:50 PM
ReaperAZ's Avatar
Bike(s): I used to be cool.
Rep: ReaperAZ is just really niceReaperAZ is just really niceReaperAZ is just really niceReaperAZ is just really nice (350)
Send a message via AIM to ReaperAZ Send a message via MSN to ReaperAZ Send a message via Yahoo to ReaperAZ
Re: tire removal
As CBRVFR said, you should not have to removed the fender. I have swapped my tires out many times this year and have never had to take the fender off my 600RR.
ReaperAZ is offline
View ReaperAZ's Profile View ReaperAZ's Gallery Find More Posts by ReaperAZ
Old 05-05-2006, 1:28 PM
Send Maple Clarice
sheepofblue's Avatar
Re: tire removal
not WD as it is a penetrating lube that is meant to DRY out with time. Also I undo the caliper and put them on the fender so they don't dangle.
sheepofblue is offline
Old 05-05-2006, 1:34 PM
luvtolean's Avatar
Bike(s): Puch
Re: tire removal
Sheep, I can show you the exhaust pipe on my CR250 which was sprayed at least 2 months ago and is still damp/slick to the touch.
If anything though, I use grease on the axles.
luvtolean is offline
Old 05-05-2006, 1:46 PM
Send Maple Clarice
Re: tire removal
According to WD40 you are correct but I would not use it on my equipment
Old 05-06-2006, 11:50 PM
Re: tire removal
are the spacers any big deal??
and I assume the rear is basically the same process, and what size socket fits for the rear on '03 600 rr?? its freaking huge.
at track day events, do they require you to take the rotors off, too?
KF810 is offline
Old 05-07-2006, 12:44 AM
Mr. Brownstone
Bike(s): 05 600RR
Re: tire removal
The rear socket is a 32mm on the '05, I assume it's the same on the '03.
And why on earth would you remove your rotors to get your tires changed?
BDA116 is offline
Old 05-07-2006, 1:19 AM
The track is the place to be
Gecko5's Avatar
Bike(s): 03 600RR
Rep: Gecko5 is on a distinguished road (14)
Re: tire removal
Socket sizes are 22mm on the front and 27mm and 32mm on the rear for an 03-04.
Gecko5 is offline
View Gecko5's Profile View Gecko5's Gallery Find More Posts by Gecko5
Old 05-07-2006, 7:21 AM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (788)
Re: tire removal
Yes, the spacers are a very big deal. They aren't alike and have to be reinstalled correctly, otherwise you can get binding of the wheel.
Not sure what you mean about the rotors and track days...
Red Rider is offline
Old 05-07-2006, 10:58 PM
Re: tire removal
well, I was going to take the tire off myself and take to the shop. the shop i normally go to was backed up for about a week. and this new shop told me that if i were to bring in just the tire, that i would have to take the rotors off too. yeah, i know. i thought it sounded odd, too, but i just wanted the damn tire on
KF810 is offline
Old 05-07-2006, 11:01 PM
Re: tire removal
i had a hard enough time finding a 22mm socket, so where the hell am i suppose to find a 27mm & 32mm??
KF810 is offline
Old 05-08-2006, 2:53 AM
Bike(s): 01 HONDA CBR 929 ERION
Rep: ALVAROG1983 is on a distinguished road (10)
Re: tire removal
snap on tool truck or sears not hard to find
ALVAROG1983 is offline
View ALVAROG1983's Profile View ALVAROG1983's Gallery Find More Posts by ALVAROG1983
Old 05-09-2006, 3:28 PM
Gecko5's Avatar
Bike(s): 03 600RR
Re: tire removal
I picked my sockets at sears. Those two socket sizes only come in 1/2 inch drive. So, you will also need an two or mixture of 1/2 inch socket wrench or a "brake bar" (does not have the ratchet mechnism at the end). Should also have a torque wrench that could be 1/2 in. drive. Or buy one of the sizes in a wrench.
27mm: http://www.sears.com/sr/javasr/search.do?BV_UseBVCookie=Yes&verticalFullName=Tool s&keyword=27mm&displayTarget=searchresults&gobutto n.x=0&gobutton.y=0&gobutton=find
32mm: http://www.sears.com/sr/javasr/search.do?BV_UseBVCookie=Yes&verticalFullName=Tool s&keyword=32mm&displayTarget=searchresults&gobutto n.x=0&gobutton.y=0&gobutton=find
Gecko5 is offline
Old 05-09-2006, 3:43 PM
  #15
Bike(s): FASTER THAN YOUR SISTER!!!
Rep: LUCIDDREAM57 will become famous soon enough (64)
Re: tire removal
geeze, and the wheel isn't even off yet! I can't wait until the thread develops into manual mounting and manual balancing, oh what fun!!
LUCIDDREAM57 is offline
View LUCIDDREAM57's Profile View LUCIDDREAM57's Gallery Find More Posts by LUCIDDREAM57
Old 05-09-2006, 3:47 PM
  #16
schnogg's Avatar
Bike(s): 2000 929 (sold), 2007 GSXR 750
Rep: schnogg is on a distinguished road (35)
Re: tire removal
Removing the rotos is not (necessarily) a bad idea because they are very fragile.
schnogg is offline
View schnogg's Profile View schnogg's Gallery Visit schnogg's homepage! Find More Posts by schnogg
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:23 AM.
