Supporting Bike with a Sears Motorcycle Lift
Old 05-09-2006, 8:45 PM
Bike(s): 1999 CBR900RR, 1983 Suzuki GS750T
Rep: CBRBethesda is on a distinguished road (10)
Is it possible to lift this bike with a traditional motorcycle lift from Sears? I have to drop the front forks down 10mm and replace the rear dogbone to the stock unit.
CBRBethesda is offline
View CBRBethesda's Profile View CBRBethesda's Gallery Visit CBRBethesda's homepage! Find More Posts by CBRBethesda
Old 05-09-2006, 8:56 PM
Bike(s): FASTER THAN YOUR SISTER!!!
Rep: LUCIDDREAM57 will become famous soon enough (64)
Re: Supporting Bike with a Sears Motorcycle Lift
Which bike?? It appears you have two.
LUCIDDREAM57 is offline
View LUCIDDREAM57's Profile View LUCIDDREAM57's Gallery Find More Posts by LUCIDDREAM57
Old 05-09-2006, 8:58 PM
ConqSoft's Avatar
Bike(s): 2007 Honda ST1300
Well, since he posted in the CBR600 forum, I would assume it was that one.
You may be able to use that lift if you remove all the plastic. I can't remember if the exhaust is in the way though.
You can lift the rear with a standard rear stand and use jack stands under the rearsets. (worked for our 600RR when I lowered it)
My Blog
GPS Discussion Forum
ConqSoft is offline
Old 05-09-2006, 9:02 PM
ok..........damn that little forum room tree placed right before the ad........I might want to check that out from time to time.
Old 05-09-2006, 9:04 PM
I am going to remove the plastics tomorow to pull the carbs. I will peak underneath the bike to check to see if the header is in the way... Hopefully not.
Old 05-09-2006, 9:57 PM
abtech's Avatar
Bike(s): 2007 RC51
10 mm drop on the forks? That's nearly 1/2". Are you certain this is what you want to do?
abtech is offline
Old 05-09-2006, 10:35 PM
The girl I bought the bike from has the front shocks lowered and a dog bone put inm the back to accomadate her short height. They are supposed to sit even at the top right? Also I bought F# suspension on Ebay. Where would I mount the shock canister?
Old 05-10-2006, 7:47 AM
abtech's Avatar
Bike(s): 2007 RC51
I misunderstood what you are doing. I'm not certain on the earlier 600s, but raising the front end back to the stock setting (which will be close to flush) and getting the rear back to stock height will make the bike handle better and have a lot more ground clearance.
Re the nitrogen reservoir, I would get some rubber material and place it between the reservoir and the subframe tube and clamp it on with hose clamps. Just make certain you don't restrict any tire clearance and that the hose won't get kinked.
abtech is offline
Old 05-10-2006, 9:33 AM
Mr. Brownstone
Bike(s): 05 600RR
You could get the rear passenger pegs from an F3. They have the mount for that remote reservoir. If you don't want to do that, then the method abtech outlined is the way to go.
And I had the fork tubes showing 4mm above the triples on my F3. Don't remember the F2 settings, but I'm pretty sure it was the same.
BDA116 is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:31 AM.
