Need Help with Electrical Problem
Old 08-21-2006, 11:00 AM
Bike(s): 2005 Honda CBR600F4i
Rep: keelboat is on a distinguished road (10)
New 2005 CBR600F4i.
Has shut off three times while driving, each time the clock resets. The last time was in a corner causing the rear wheel to skip and I had to lay down teh bike.
Took it in under warranty t o the dealerhsip. They said the removed the battery & load tested. Turned out OK. Checked all fuses - OK. Tested bank angle sensor - OK. Checked grounds - OK. No codes were stored in memory. No probelms were found.
Any ideas on what is wrong? Thanks in advance.
keelboat is offline
View keelboat's Profile View keelboat's Gallery Find More Posts by keelboat
Old 08-21-2006, 12:38 PM
cvc14's Avatar
Bike(s): 2001 Honda F4i - Some crash damage
Rep: cvc14 is on a distinguished road (30)
Send a message via AIM to cvc14 Send a message via Yahoo to cvc14
Re: Need Help with Electrical Problem
First off ...
Now do you have anything done to the bike? Like added neon's or something like that? Removed lights and or added anything like this?
Are you doing anything special while the bike cuts out? How often has this problem happened? Same day different days?
I am not a expert here but since Honda said everything was fine and the computer has not error codes in it. Then it should be good.
But I would try and get my hands on another ECU and try that out and see if it helps. Also you might want to check the guages. I know when you unplug them you will reset the clock and the bike will not run with out them ..
cvc14 is offline
View cvc14's Profile View cvc14's Gallery Visit cvc14's homepage! Find More Posts by cvc14
Old 08-21-2006, 1:10 PM
kawboy69's Avatar
Bike(s): POS '04 ZX-10R
Rep: kawboy69 is a jewel in the roughkawboy69 is a jewel in the roughkawboy69 is a jewel in the roughkawboy69 is a jewel in the rough (329)
Check you battery conections, wiring harness plugs, grounds and fuse panel...Hope this helps..
kawboy69 is offline
View kawboy69's Profile View kawboy69's Gallery Find More Posts by kawboy69
Old 08-21-2006, 5:47 PM
Thanks for the welcome and for the tips. That all sounds promising.
Nothing has been added to the bike. It is still stock. It has cut out and died three times. The first time was in the driveway, moving slowly. It started right back up. The second time was pulling into an apartment complex. Again, it was slow and so no harm, but it wasn't as if the bike was going over anything bumpy. The third time it died while turning left in a city street. That time, since it was leaning a bit, I laid it on its side. Each scenario was a bit different - no rhyme or reason really.
I will look into the gauges and the other connections. If anyone thinks of anything else or has had a similar experience, I would appreciate the wisdom.
keelboat is offline
Old 08-21-2006, 6:35 PM
Meatarian
CBR929RE's Avatar
Bike(s): 01 R/B 929
2 friends had similar situations last year (01 F4i and 05 GSXR600).
they both cut out a few times on them last year fo no reason. even on the highway a couple of times, once we had to pull over because it (gsxr) wouldn't start back up for a few minutes. we never found any problems with either bike. I haven't ridden with either of them too much this year but haven't heard of the issue coming back.
CBR929RE is offline
Old 08-21-2006, 7:57 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (788)
I'd suspect the battery since it's resetting the clock when it quits. Replace it and check to make sure your connections (especialy ground) are clean and tight. Don't assume your dealer checked everything...
Red Rider is offline
Old 08-21-2006, 8:57 PM
Bike(s): 2002 954rr
Rep: zx9r420 is on a distinguished road (10)
cheak your kick stand switch we had a bike come in to the dealership that died sometimes after diag we found that the switch was bad
zx9r420 is offline
View zx9r420's Profile View zx9r420's Gallery Find More Posts by zx9r420
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 8:36 AM.
