CBR 600 F4i Burning Oil - Help Needed
Old 11-06-2006, 12:15 AM
Bike(s): CBR 600
Rep: cbrsam is on a distinguished road (10)
My bike sat in the garage for a few months and I tried to start it a few weeks ago. Cylinders 2 & 3 were not firing, and I traced the problem to a leaking fuel pressure regulator (thanks to another thread here). I replaced the regulator, but now the bike seems to be burning oil under load and when the bike is warmed up (a lot of white smoke and smells like oil). During idling for 15 min though, there is little or no smoke. The bike only has about 6k miles on it.
If it was the rings, shouldn't it have more smoke when cold? What else could cause the bike to burn oil? Valve guides?
Any ideas or troubleshooting tips are appreciated.
Thanks
cbrsam is offline
View cbrsam's Profile View cbrsam's Gallery Find More Posts by cbrsam
Old 11-06-2006, 1:42 AM
Repeater's Avatar
Bike(s): 2001 F4i
Rep: Repeater is a jewel in the roughRepeater is a jewel in the roughRepeater is a jewel in the rough (274)
Re: CBR 600 F4i Burning Oil - Help Needed
Did you replace the oil? If if so check to make sure you didn't put to much in.
Repeater is offline
View Repeater's Profile View Repeater's Gallery Find More Posts by Repeater My Map Location
Old 11-06-2006, 2:07 AM
Bike(s): CBR 600
Thanks... didn't change the oil.
cbrsam is offline
Old 11-06-2006, 2:38 AM
Change the oil and take your bike out for a long ride. That should take care of the smoking problem. Hopefully gas wasn't in the oil. Gas doesn't lubricated well at all and can seize the engine.
dattaway is offline
Old 11-06-2006, 8:11 AM
abtech's Avatar
Bike(s): 2007 RC51
Oil smoke is usually blue. White smoke is usually gas or water/gas.
abtech is offline
Old 11-06-2006, 10:27 AM
Bike(s): CBR 600
I'll take a closer look at the color of the smoke and change the oil out, then ride it around to burn off anything in the exhaust. Will let you know how it goes.
Thanks for the great advice!
cbrsam is offline
Old 11-06-2006, 10:28 AM
ND4SPD's Avatar
Bike(s): '84 Magna V30
Look for sludge in the oil too. If it's brown-ish, water got into it.
ND4SPD is offline
Old 11-12-2006, 4:09 AM
Bike(s): CBR 600
I changed the oil today and turns out there was gas mixed in with it! I guess it got in the crankcase from the 2 flooded cylinders that were not firing. Anyway, the oil change worked great and the bike no longer smokes. I thank you all and so does my bike!
cbrsam is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 5:45 AM.
