F4 wont start
Old 11-19-2006, 11:54 PM
Wes
Bike(s): Honda CBR 600 F4 2000
Rep: Wes is on a distinguished road (10)
F4 wont start
My CBR 600 F4 wont start. Im guessing it has to do with the plugs, not sure. The battery has a good charge and will turn over the engine, but it quits like 5 secinds after the ignition. The quiting time becomes less and less as you attempt to start it. On the final attepmt, it pops as it quits, shooting a falme out of the exhaust. What should i do to fix this? Does it just need new spark plugs or does the problem possible go deeper than this?
Wes is offline
View Wes's Profile View Wes's Gallery Find More Posts by Wes
Old 11-19-2006, 11:59 PM
Wes
Re: F4 wont start
Does the fact that it's cold in my garage (around freezing, or just above) have anything to do with this problem, i dont know if it should as my brothers F3 starts up fine...
Wes is offline
Old 11-20-2006, 12:08 AM
Blow me.
phobiaphobe's Avatar
Bike(s): 998RR4
Re: F4 wont start
Something obstructing the intake?
phobiaphobe is offline
Old 11-20-2006, 1:01 AM
Wes
Re: F4 wont start
Im not sure. How would I check for this?
Wes is offline
Re: F4 wont start
Sounds like a fuel problem. Been sitting up for a while? You can make sure fuel is in the carbs by flipping the key between off and on a dozen or so times. You can hear the diaphram pump do its thing for a second each time until the carbs are filled. If the jets are clogged, it might be a bit difficult to get fresh gasoline to clean them out.
You can purge the cylinders with fresh air by cranking with an open throttle. After that, closing the throttle will create vacuum and help to fog the gas, creating a perfect combustion climate.
Alternating between open and close may help meter some fuel in there and letting it atomize.
dattaway is offline
Old 11-20-2006, 1:20 AM
Wes
Re: F4 wont start
I tried cranking the throttle open, and then closing it while the bike was on(does it make a difference if it is off?).. did this a few times as well as turning the bike off and on a dozen times.. still gives me the same response though.. Im thinking it has to deal with the spark plugs as there seems to be unburnt fuel causing the pop.. does that seem to follow any logic?
Wes is offline
Old 11-20-2006, 5:02 AM
Re: F4 wont start
I clean the spark plugs by taking them off and heating up the insulator with a blow torch. Makes them good as new.
dattaway is offline
Old 11-21-2006, 12:07 AM
Wes
Re: F4 wont start
Thanks for all the help fellas'.. i took off the tank and drained out the carberators, they were full of fuel i guess..so its running beautifuly now!... just a side note~ turns out, there isnt a diaphram pump on honda bikes, the pump runs as the engine turns over...
but thanks for the help so quickly there...
Wes is offline
Old 11-21-2006, 12:43 AM
Custom900's Avatar
Bike(s): The REAL KING - Hayabusa
Rep: Custom900 has a spectacular aura aboutCustom900 has a spectacular aura aboutCustom900 has a spectacular aura about (231)
Send a message via AIM to Custom900
Re: F4 wont start
You will find that cleaning motorcycle plugs is a useless feat. Buy new ones
Custom900 is offline
View Custom900's Profile View Custom900's Gallery Find More Posts by Custom900
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:43 PM.
