Front forks
Old 11-30-2006, 5:28 PM
Bike(s): RD350, RGV250, CBR600F2
Rep: Raoooul is on a distinguished road (10)
Front forks
Hi, I was trying to change my fork seals and I used a cheap set of hex keys (stupid stupid stupid) which absolutely rounded one of my bottom bridge pinch bolts on one of the fork legs. As a result I cant get the bolt off and cant get the slider or fork seal out to replace it. Does anyone have any ideas on how I can get the seal changed or somehow remove the defective bolt?
Raoooul is offline
View Raoooul's Profile View Raoooul's Gallery Find More Posts by Raoooul
Old 12-01-2006, 12:27 AM
Nickelii's Avatar
Bike(s): 600RR track bike
Rep: Nickelii has a spectacular aura aboutNickelii has a spectacular aura about (196)
Re: Front forks
I believe they have a kit you can buy called EZout (sp?). I think that you drill a small bit into the bolt and it comes out pretty easily. I have never used it or personally seen it, but have heard about it. If you have enough room you could also dremmel a cut in the head of the bolt and then use a flat head screw driver to back it out. I am by no means a mechanic, nor am I mechanically inclined so good luck. You should also get an okay set of hex keys if yoou do your own maintenance. Cheap, but decent hand tools can be found at harborfreight.com
Nickelii is offline
View Nickelii's Profile View Nickelii's Gallery Find More Posts by Nickelii
Old 12-01-2006, 9:51 AM
Mr. Brownstone
Bike(s): 05 600RR
Re: Front forks
Craftsman 52154 3 pc. Screw-Out™ Damaged Screw Remover Set at Sears.com
BDA116 is offline
Old 12-03-2006, 5:55 PM
Bike(s): 1992 CBR 600 F2
Rep: WhistlerX is on a distinguished road (10)
Re: Front forks
I did the samething about two weeks ago.. I went to honda and they removed it for about $25 bucks, kinda a rip but then again cheaper than replacing the fork.. the craftsmen idea is a good bet as well. good luck!
WhistlerX is offline
View WhistlerX's Profile View WhistlerX's Gallery Find More Posts by WhistlerX
Old 03-23-2007, 4:53 PM
Bike(s): 2003 CBR954RR, 1996 CBR600F3, 2001 Yamaha Jog
Rep: LITEITUP is on a distinguished road (45)
Re: Front forks
I know this is old but hey more info equals more help right? If I strip a screw I dont even mess with ez outs. Ive tried them and they just dont work for me. I just get a drill bit (good one), slightly bigger than the head of the bolt you want to take out, and drill it out. Just keep drilling and when you get close to the threaded part it will either pop off or just get some pliers and pull the head off. Works everytime with no bad results.
LITEITUP is offline
View LITEITUP's Profile View LITEITUP's Gallery Find More Posts by LITEITUP
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:58 AM.
