12-20-2006, 1:28 PM
Bike(s): CBR 600F2 Posts: 5
| winterize your bike? what do you do (maintenance wise) when you store your bike ove the winter, and then upon getting it ready again? |
12-20-2006, 1:33 PM
Bike(s): POS '04 ZX-10R Age: 39 Posts: 1,475
| Re: winterize your bike? Make sure that you have the proper amount of anti-freeze in it and put it some where dry and warm if possible..Then when winter is over I change and flush all fluids and oil and filters. Then you should be ready..Also check your tires for dry rott and the air pressure...Hope this helps... |
12-20-2006, 3:26 PM
#3 | | Carolina Kracker
Bike(s): 06 CBR1000rr, 05 CBR1000RR Repsol Edition(stolen) Age: 25 Posts: 4,696
| Re: winterize your bike? what is this "winterize" that you speak of doing to your precous |
12-20-2006, 4:39 PM
#4 | | gone green
Bike(s): 95 VFR Age: 92 Posts: 1,638
Rep:   (100) Rep Power: 6
| Re: winterize your bike? Quote:
Originally Posted by danadeny what do you do (maintenance wise) when you store your bike ove the winter, and then upon getting it ready again? | Well I dont know about you "New Englanders" but I winterize my bike by turning on my heated grips.  to the .org
-jh
__________________ - Track whores get paid for it, track sluts do it for free...
- Cars lean the wrong way in turns. |
12-20-2006, 5:34 PM
| Re: winterize your bike? Fill gas tank to top and add Stabil as described on the label. Run bike for about 10 mins to distribute stabilized gas throughout system.
Make sure antifreeze is in
Change oil and filter. Do not store your bike with dirty oil in it, as it contains breakdown products that can be corrosive. Unless the bike is stored for more than 6 months, or in a very humid environment, you can use this oil in the Spring.
Bring the battery inside and put it on a one amp trickle charge overnight once a month. Or, hook it to a battery tender.
If possible, get the wheels off the ground. Or, inflate them to a bit over normal and park on cardboard to insulate them a bit from the cold cement.
Clean, wax, put on a coat of chain lube
Cover the end of the exhaust, and the airbox if it's open, to keep critters out.
Cover with a sheet or some breathable cover to keep dust off.
In the spring, put the charged battery in, take the cover off the exhaust, start and go! |
12-20-2006, 6:35 PM
#6 | | maybe because it does not really matter...........
Bike(s): 94 CBR 900RR Age: 36 Posts: 1,267
Rep:   (127) Rep Power: 5
Originally Posted by Quick 26 what is this "winterize" that you speak of doing to your precous | Not in the 37042 either!  |
12-20-2006, 7:53 PM
#7 | | gone green
Originally Posted by HondaGalToo Fill gas tank to top and add Stabil as described on the label. Run bike for about 10 mins to distribute stabilized gas throughout system. |  on what she said but...........er........... WHY WOULD YOU WINTERIZE IT??!!
I've heard of this phenomenon but just cant understand it.
-jh
12-20-2006, 8:15 PM
| Re: winterize your bike?  I hate riding in below 55 degrees F weather. If I have to put that many layers on, I'm going skiing. I can't be bothered with electrics. Just not my thing, but I have friends who do ride all winter long. Then there's that issue of getting road salt all over my ride. No thanks!  |
12-20-2006, 8:47 PM
#9 | | gone green
Originally Posted by HondaGalToo  I hate riding in below 55 degrees F weather. If I have to put that many layers on, I'm going skiing. I can't be bothered with electrics. Just not my thing, but I have friends who do ride all winter long. Then there's that issue of getting road salt all over my ride. No thanks!  | | PANSY! | |
12-20-2006, 8:50 PM
Bike(s): YAMAHA R-1, WR450F Age: 44 Posts: 5,397
| Re: winterize your bike? This concept confuses me as well. And just what is this "winter" you speak of anyways?
And before you start, it was 17 here today. In the AM, before the sun came up... though it was 53 this afternoon.
AND, if you do a search you will get plenty of advice as well as more of mine and others "clever" remarks.  |
12-21-2006, 6:28 AM
Originally Posted by jhonda41 | PANSY! | | | Yup, can't argue with you! |
