Low compression in all cylinders 03 600RR
Old 01-14-2007, 5:28 PM
Bike(s): 2003 CBR600RR - road bike & 2000 R6 track bike
Rep: Gluaisrothar is on a distinguished road (10)
Hi
I have been advised by a main dealer mechanic that I have low compression in all cylinders on my (8500 miles on odometer) 03 600RR. The problem manifested itself as the bike refusing to start despite a fully charged battery. I checked oil level, fuses and everything that the Honda service manual suggested. I thought I had it traced to the oil pressure sensor, but that wasn't it either. The low oil pressure light was still illuminated and the engine wouldn't start. I took it to the main dealer on a trailer with what I thought was an electronic/electrical problem. They tell me that it is either a valve, cylinder or cam chain problem most likely caused by a lack of oil. It'll be at least $800 (on top of the $300 to get this far) in labo(u)r ... before any parts! Some have suggested that it would be cheaper to source an engine on ebay and have it switched for the one in my CBR.
Any advice would be welcome.
Thanks
Gavin
Gluaisrothar is offline
View Gluaisrothar's Profile View Gluaisrothar's Gallery Find More Posts by Gluaisrothar
Old 01-14-2007, 7:48 PM
Hammer's Avatar
Bike(s): GSXR Stunt Bike
Rep: Hammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud ofHammer has much to be proud of (1355)
Re: Low compression in all cylinders 03 600RR
Originally Posted by Gluaisrothar View Post
Hi
Thanks
Gavin
Who is the dealer?
Hammer is offline
Old 01-14-2007, 8:14 PM
The dealer is Honda of Indianapolis.
Old 01-14-2007, 8:51 PM
Hammer's Avatar
Where in the hell are they at? Never heard of them, the only Honda dealer I know of is Dreyer Honda on West Washington Street.
Hammer is offline
Old 01-14-2007, 9:14 PM
Bike(s): 03 CBR954RR, 03 V-Rod, 02 YZ250, 98 YZ125, 72 S2
Rep: dchd1130 is on a distinguished road (10)
you need to find out what it is and the only way will probably be to pull the valve cover off I dont know if you have to remove the whole engine on this bike or not. If you havent ran it with out oil I would assume it is something in the valve train. If you are not able to pull the head your self you are at the mercy of the stealer. I would pull it apart my self before I went looking for a new engine. Either way the engine has to come out.
dchd1130 is offline
View dchd1130's Profile View dchd1130's Gallery Find More Posts by dchd1130 My Map Location
Old 01-14-2007, 10:27 PM
ichsnoo's Avatar
Bike(s): '02 954RR, '03 FZ1, '93 CBR600, '89 ZXR750
Rep: ichsnoo is on a distinguished road (24)
You definitely need to have the valve clearances checked before making a decision on what to do. Did the dealer check the clearances and also indicate how far past the serviceable limits each inlet and exhaust valve was? For $300 U.S I hope that they have specified exactly what is wrong.
If it is a valve issue then you will probably be able to find a mechanic who can do the work cheaper than a Honda dealer. You should also be able to get replacement parts a bit cheaper than what Honda can supply too.
Cheers,
Dave
ichsnoo is offline
View ichsnoo's Profile View ichsnoo's Gallery Find More Posts by ichsnoo
Old 01-21-2007, 8:38 PM
Bike(s): 05 CBR1000RR, Supercharged V65 Magna
Rep: C420sailor is on a distinguished road (14)
do a leakdown test NOW. if they don't know whether it's head gasket, valves, or rings, then they didn't do an adequate inspection of the bike.
C420sailor is offline
View C420sailor's Profile View C420sailor's Gallery Find More Posts by C420sailor
Old 01-23-2007, 11:05 PM
Thanks Guys. I'm going to take the bike to another dealer and get a leak down test done. I know that the current dealer hasn't done one, even they did mention it to me.
Old 01-23-2007, 11:17 PM
let us know what you find.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:00 AM.
