| Re: Dump the anit-freeze, why????? For those of us that do trackdays, antifreeze removal is required by the track orgs, because if someone wrecks and it spills, it's very slippery. Other riders would then potentially crash from sliding on it, and it takes a long time to clean off the track. For street only riding, there's no real reason to switch to distilled. If you do, get some Redline Water Wetter and add the amount stated on the bottle to the distilled water, as it will provide lubrication for the pump. Your bike will run cooler on it compared to antifreeze, but again, that's mostly a benefit on the track where you're running the bike at high rpms. |
