02-08-2007, 10:33 AM
Rep:  (98) Rep Power: 0
| Clutch Cover Change I'm getting ready to change out my clutch cover, I have read the service manual and everything seems pretty straight forward but was wondering if anyone has any suggestions/hints/tips on any surprises that I may encounter while doing this. Just wanted to add... this is for an 02 CBR600F4i. |
02-08-2007, 1:35 PM
Bike(s): 03 954RR Posts: 78
Rep:  (10) Rep Power: 4
| Re: Clutch Cover Change Dunno about the clutch cover but if it's similar to the stator cover, you'll need a new gasket and the gasket filler material. If you have the manual you should be fine. |
02-09-2007, 11:44 AM
Bike(s): 2001 CBR 929rr Posts: 263
Rep:  (16) Rep Power: 3
| Re: Clutch Cover Change its really easy just remove it and replace the gasket. I can't remember what you do about the clutch cable the goes through the top of it.
02-09-2007, 11:49 AM
| Re: Clutch Cover Change Quote:
Originally Posted by Triax it's cake do'nt sweat it. I did it on my F3, i just held the cable with some pliers as to stretch it back in the lever but its really easy. What levers are you installing on there? | Wish thats what I was doing, the Clutch Cover I'm talking about is also known as the right side crank case cover. |
02-09-2007, 1:39 PM
#5 | | Team Visa Racing
Bike(s): 04 GL1800A,00 929RR,87 CR500R,81 CB900F,71 CB836K1 Age: 45 Posts: 3,858
| Re: Clutch Cover Change Nothing to it. Disconnect the clutch cable and remove the bolts. While you have it out, why not replace the clutch arm shaft seal?
Permatex now has a motorcycle specific silicone sealer that works GREAT! Gray in color. I've used it before. Ron Ayers Motorsports - Discount Motorcycle Parts
Ride Red
02-09-2007, 1:47 PM
Originally Posted by nedro Nothing to it. Disconnect the clutch cable and remove the bolts. While you have it out, why not replace the clutch arm shaft seal?
Permatex now has a motorcycle specific silicone sealer that works GREAT! Gray in color. I've used it before. Ron Ayers Motorsports - Discount Motorcycle Parts | Might as well, I'm guessing that it will just pop out with a little pressure from the inside? Speaking of the clutch arm, the manual says to rotate it to disengage it from something before removing, any problems getting it to regrip that or just as simple as have it twisted before seating it and it will grab a hold on its own? |
02-09-2007, 2:07 PM
#7 | | Team Visa Racing
| Re: Clutch Cover Change I don't know but would assume that the shaft is "D" shaped and you have to rotate the shaft so the flat part goes past the obstruction. Putting it back the way you took it out is probably how to do it.
Ride Red
02-09-2007, 3:34 PM
| Re: Clutch Cover Change yeah sorry about that. I wrote it and then was like wait i'm think of the wrong thing and edited it. My bad. |
02-09-2007, 3:35 PM
Originally Posted by Triax yeah sorry about that. I wrote it and then was like wait i'm think of the wrong thing and edited it. My bad. | Its all good  |
03-07-2007, 12:22 PM
| Re: Clutch Cover Change Is there a gasket that goes on here or just sealant? I'm having NO luck finding a gasket for it. |
03-07-2007, 2:13 PM
#11 | | Team Visa Racing
| Re: Clutch Cover Change Was there one when you took it off?
It sure doesn't show one.
Ride Red
03-07-2007, 2:18 PM
| Re: Clutch Cover Change Haven't taken it off yet (wanted to make sure I had all parts first). It just seemed odd to me that there wouldn't be a gasket there (as told to me by the bike shop). They are saying it just gets some sealant and bolts back on and I'm down the road. |
03-07-2007, 2:27 PM
#13 | | Team Visa Racing
| Re: Clutch Cover Change I wonder if they did that strickly for stock production racing (Quicker repairs)?
Ride Red
03-07-2007, 3:27 PM
#14 | | Carolina Kracker
Bike(s): 06 CBR1000rr, 05 CBR1000RR Repsol Edition(stolen) Age: 25 Posts: 4,696
| Re: Clutch Cover Change there are a few bikes that dont use gaskets. |
03-07-2007, 3:28 PM
#15 |
| Re: Clutch Cover Change Just seems to me as if its asking for trouble by not using one. |
03-07-2007, 3:54 PM
#16 | | Carolina Kracker
| Re: Clutch Cover Change i have a atv that has no center case gasket, not because i didnt want to leave it out, but they dont make one for it |
03-07-2007, 4:00 PM
#17 | | 2-Up SISSY
Bike(s): 2002 CBR 600F4i / 2003 XR650R 'Tard Age: 29 Posts: 2,561
Rep:   (196) Rep Power: 5
| Re: Clutch Cover Change I've used permatex RTV in place of a lot of different gaskets and have been pretty happy overall so I don't see why just going with sealant should be a problem. Especially with whatever this new "super gray stuff" is that nedro is talking about. Get some of that and then pull it apart.
03-07-2007, 8:16 PM
#18 |
| Re: Clutch Cover Change i got yamabond (no one around here had the permatex stuff). talked to two shops and both suggested this stuff. i'll let you all know how it goes
03-15-2007, 8:42 PM
#19 |
| Re: Clutch Cover Change Okay so you may have read in another thread I cracked the first cover that I went to put on  Got another one and put it on tonight. Threw some new oil in it and WOW that oil was dirty as all get out because with that nice new oil in her she is purring like a kitten again! the yamabond held up great easy to use and drys fast. |
03-16-2007, 7:41 AM
#20 | | Carolina Kracker
| Re: Clutch Cover Change |
