| F4i Engine Rebuild Ok, so i've rebuilt car motors before, and i've never had this problem..
I have a shop manual, and I follow it to a "t". Plastigauge says the new bearings have the proper clearance. But when I assemble the two block halves and torque them to proper specs (25 N-m), the crank is seized! Now if I torque to to half the spec 12.5 N-m, the crank turns ok... I only have the crank in, no rods or pistons... The bolts are torqued in a criss-crossing pattern, etc.
I have my suspicions as to what the problem is, but I'm not ready to admit it... Let's see if anyone agrees with my suspicion,
IDEAS? |
