Problem with starting up my bike
Old 02-18-2007, 5:11 PM
Bike(s): Honda CBR600F4i 2002
Rep: rodrigoblanco is on a distinguished road (10)
Greetings, I have a cbr600f4i 2002 the thing is i dropped it and a fissure was made to the stator cover, had the cover fixed, and reinstalled it, but now the bike won't start up, maybe you could help me...before i take the cover off, the bike ran and driven well, but now nothing, the battery was almost dead because i took a long time to fix it, but i putted a booster to fix that, now all the indicators light up right, the FI turns off, the gas pump souns good, but when i push the igniton switch there's only a sound like when a DC motor turns (I think is the starter motor that is running with no load on its axis, or maybe the gas pump works when you startup the bike i'm not sure), but then nothing the engine doesn't even try to move to startup. Maybe something came loose whe i took off the cover, a pinion or something; i also moved what i think is the flywheel but it just turned clockwise because counter clockwise movement was impossible, i think this is why somebody asked if his affects timing in the bike. I hope you could help me. Thanks!
rodrigoblanco is offline
View rodrigoblanco's Profile View rodrigoblanco's Gallery Find More Posts by rodrigoblanco
Old 02-19-2007, 7:46 AM
Bike(s): 2002 CBR600F4i
Re: Problem with starting up my bike
I don't think turning that will hurt anything as far as timing goes. Now as far as why the bike isn't turning over sorry but I don't know, its not something stupid like the kill switch is it? (not calling you stupid just saying its one of those stupid things that is easily overlooked)
sinfuldragon is offline
Old 02-20-2007, 7:51 AM
No it was not the kill switch, i found what the problem was, the pinion that gives transmission from the starter motor, to the attack pinion of the starter clutch have a shaft that guides it through, i left the bike a long time sitted on the sidestand with the cap off, so i guess the bike moved and the pin came off, i don't have a pin, and there's no one here where i live that has the original spare part for the bike (just what i needed) jajaja! I'd like to know if someone has had that pin measured or knows a link that has the pin measures, it's a pin with a hole in the middle i think it's build of stainless steel 10-14, i'll have to make one here but i'd like to know a few things first, like if it turns with the pinion, or if just the pinion turns and the pin stands. Maybe somebody knows about this! Thanks in advance.
Old 02-20-2007, 7:56 AM
After work I'll see if I can find something about that pin in the manual, if it will give me the specs I'll be happy to pass them on.
Old 02-20-2007, 8:02 AM
Hey thanks a lot! i'd really appreciate it! i'm posting the picture of the pin maybe i'd help a little. Thanks again!
Old 02-20-2007, 6:41 PM
Sorry bud, just looked through the service manual and it only talks about that dowel pin enough to say take it out and reinstall it. Doesn't give any dimensions of it at all.
Old 02-20-2007, 10:28 PM
Thanks a lot anymay man! i guess i'll have to measure everything and give it a try. I'll drop a note when i got it done and tell you how it worked.
Old 02-22-2007, 4:26 PM
Okay, In the meantime I'll let you know if I can find this part online anywhere. So far I don't even see it to buy!!
Old 02-22-2007, 4:29 PM
Oh yeah I did. But from the looks of your picture you have found in on BikeBandit.com as well. If thats not the case and you would like a link to the page that has the part for sale just let me know.
Old 02-23-2007, 8:48 AM
Yes, please send me the link!
Old 02-23-2007, 9:11 AM
Here you go. I figured you already had it because the pictures are pretty much 100% the same. Anyway here you go
OEM (Stock) Parts 2002*Honda*CBR600F4** Starting Clutch Parts at BikeBandit.com
Old 06-06-2007, 12:07 AM
Greetings, i finally have time to write, i made the pin and it worked just fine, the pin measures i used were 10mm diameter and 39 mm long, i'm finally riding my bike again, but i'll have to get the original one soon.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:53 AM.
