2001 f4i forks
Old 02-22-2007, 11:58 PM
Bike(s): CBR600f4i-01, CRF450R-03, VFR800-07
Rep: waterkc is on a distinguished road (10)
Send a message via AIM to waterkc Send a message via Yahoo to waterkc Send a message via Skype™ to waterkc
2001 f4i forks
I am working on my cbr 600 f4i and am i replacing the front springs with some racetech srpings (95's). I am wondering what size spacer to use as the springs are a lot shorter then the orginals.
any ideas?
waterkc is offline
View waterkc's Profile View waterkc's Gallery Find More Posts by waterkc
Old 02-27-2007, 8:52 PM
Bike(s): '05 DucatiMonster S4R; '01 CBR600F4i (Track)
Rep: Ciao Fun is on a distinguished road (10)
Re: 2001 f4i forks
Are you installing the gold valves/ shims as well? What model/ rate are the springs?
You should call Race Tech and get a little guidance. 951.279.6655
Ciao Fun is offline
View Ciao Fun's Profile View Ciao Fun's Gallery Find More Posts by Ciao Fun
Old 02-28-2007, 6:42 AM
Bike(s): cbr fs 02
Rep: sbtgn1 is on a distinguished road (10)
Re: 2001 f4i forks
any ideas?
i am glad you ask i had the same problem when i installed mine .85 raceteck spring , at first i used the original spacer big mistake it made the sag 15 mm when the proload was soft as possible,
then then i measuerd the original spring and spacer ,and made a custum spacer that will be in the same lentgh as the racetech spring+custom spacer ,you say the stock are longer then the racetech mine was the oppsite. anyway i think you got the idea, btw my weight is 180 with equip
sbtgn1 is offline
View sbtgn1's Profile View sbtgn1's Gallery Find More Posts by sbtgn1
Old 03-03-2007, 12:54 AM
Re: 2001 f4i forks
Thanks for the info. I will try to go that route. I have all the oem stuff and will give them a measure.
I am no where near that wieght, hehe.
thanks again.
waterkc is offline
Old 03-08-2007, 12:19 AM
Re: 2001 f4i forks
well after pulling everything apart this weekend and doing some measuring and head scratching. I am going to have to call racetech. I am not sure what length the orginal spacers were, but what is in there now is 100mm spacers (which might be the stockers, just can't remember). I also noted that with the springs in place I have very little valving control. I am using 5 weight oil for now as that was what I had at the time. I might go up a little in weight, but I need to figure out the spacers first.
I must add I made this change to the bike when I bought it in 2001. But I can't find the orginal shim's so I need to do a bit more research and figure this out.
If anyone has the stock shim measurements please post them for me. I am also thinking of going th valving route as with the new springs I am sure its going to be a bit off, but who knows.
More to come.
waterkc is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 12:18 AM.
