Bike wont start
Old 03-11-2007, 4:07 PM
Bike(s): Slvr/RED F4i
Rep: AVIONLS is on a distinguished road (10)
Bike wont start
I have just purchased a 02' Cbr F4i.. Bike ran jus fine.. Was waiting for the weather to break so I could see what it could do. Got my chance two days ago. I rode for about 6hrs wit a few of my friends. about two hours before we were finished I noticed all four of my low fuel lights were flashing so we jumped off e-way and I filled up. Got home put bike up. Next day I went to start it and it wouldn't turn over.. I can no longer hear that fuel pump noise when I flip on the run switch.. Does this mean my fuel pump is bad or should I be looking else where????? Please help me best you can.. I also checked Fuses and they were all fine..
AVIONLS is offline
View AVIONLS's Profile View AVIONLS's Gallery Find More Posts by AVIONLS
Old 03-11-2007, 4:29 PM
Bike(s): 2001 CBR 929rr
Rep: Triax is on a distinguished road (16)
Re: Bike wont start
check all electrical connections before you look into the fuel pump itself
Triax is offline
View Triax's Profile View Triax's Gallery Find More Posts by Triax
Old 03-11-2007, 5:38 PM
Re: Bike wont start
I have service manual to help me pinpoint.. I jus have to get a voltage regulator so I can test and see if it is the fuel pump.. all connections look good tho.. Purchased bike last month with 9910 miles and it seemed to be well maintained
AVIONLS is offline
Old 03-11-2007, 7:38 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (769)
Re: Bike wont start
Check your battery first ...it might need replacing.
Red Rider is offline
Old 03-11-2007, 10:06 PM
Re: Bike wont start
The battery would make the fuel pump not prime?
AVIONLS is offline
Old 03-11-2007, 10:07 PM
Hardcore 365 and 24
Bike(s): CBR1000RR, GL1800
Rep: A.F.T.C.T.T.G. is on a distinguished road (17)
Re: Bike wont start
no juice=no juice
A.F.T.C.T.T.G. is offline
View A.F.T.C.T.T.G.'s Profile View A.F.T.C.T.T.G.'s Gallery Visit A.F.T.C.T.T.G.'s homepage! Find More Posts by A.F.T.C.T.T.G. My Map Location
Old 03-11-2007, 10:55 PM
Doorbell broke, please sound fog horn!
leelover's Avatar
Bike(s): 06 FJR1300
Rep: leelover is just really niceleelover is just really niceleelover is just really niceleelover is just really nice (371)
Re: Bike wont start
If the batt is low enough it won't prime the pump. Make sure your connections are clean and tight.
Check the kill switch on the right handle bar. Make sure it is fully in the on position. I would flip it back and forth a bit, corrosion can build up on these contacts easily.
Did you do anything out of the ordinary when you put it up after the last ride?
These things are often simple problems. Good luck!
leelover is offline
View leelover's Profile View leelover's Gallery Find More Posts by leelover
Old 03-11-2007, 11:38 PM
Re: Bike wont start
Nothing unusual at all.. NO corrosion at all. All lights come on and and doesn't seem to be a low battery problem. Won't no 4 shore tho til tommorow when I get a voltage meter
AVIONLS is offline
Old 03-12-2007, 12:50 AM
Wish I had a fuel gauge
Bike(s): 1998 CBR 600F3
Rep: slorider18 is on a distinguished road (48)
Re: Bike wont start
probably a voltage regulator or the battery.
slorider18 is offline
View slorider18's Profile View slorider18's Gallery Visit slorider18's homepage! Find More Posts by slorider18 My Map Location
Old 03-13-2007, 2:16 AM
Re: Bike wont start
Ok I've established ITS NOT THE BATTERY!! Boils down to Maybe the Fuel Cutoff Relay. Checked all Connections and got pump to prime manually so I no fuel pump is good.. Thats $400 still in my pocket.. Bad part is I have to order it which means I will miss out on the 73 degrees predicted 4 2mar which SUCKS!! so bad.. I used a Jumper wire at the fuel cut relay and fuel pump jus kept making priming noise.. BIKE STILL WOULDN"T START even tho I had pump on.. Does anyone no Is this because it was constantly priming??????
AVIONLS is offline
Old 03-15-2007, 11:25 AM
Re: Bike wont start
Stil cant figure this out.. Has anyone heard of any situation simular to this??? I no its somethin simple and would prefer not to let the dealer screw me on this. I have taken bike all apart.. Only thing is fuel pump isn't priming.. But pump is good. Someone anyone help me out here!!
AVIONLS is offline
Old 03-15-2007, 11:41 AM
Bike(s): 2002 CBR600F4i
Re: Bike wont start
you said you checked fuses and the fuel pump relay correct?
sinfuldragon is offline
Old 03-15-2007, 12:10 PM
Re: Bike wont start
Yes all were good
AVIONLS is offline
Old 03-15-2007, 9:28 PM
Bike(s): '99 Honda CBR 600(track only) '01 Honda Goldwing
Rep: briflight is on a distinguished road (12)
Re: Bike wont start
Are you actually getting fuel into the intakes from the fuel pump? Maybe a pluged line? Even a little water in the fuel will make it not start. Just thoughts
briflight is offline
View briflight's Profile View briflight's Gallery Visit briflight's homepage! Find More Posts by briflight
Old 03-26-2007, 8:15 AM
  #15
Re: Bike wont start
YES!!!!! ITSssss BACK!!!!! SIMPLE PROBLEM,,, SIMPLE SOLUTION
AVIONLS is offline
Old 03-26-2007, 8:19 AM
  #16
Re: Bike wont start
and the problem was?
Old 07-11-2007, 11:48 PM
  #17
Bike(s): 2003 CBR 600RR
Rep: GIX UP is on a distinguished road (10)
Re: Bike wont start
So what was wrong? I'm having a similar problem.
GIX UP is offline
View GIX UP's Profile View GIX UP's Gallery Find More Posts by GIX UP
Old 07-15-2007, 6:08 PM
  #18
Bike(s): 2002 R1, 2003 F4i, 2002 gsxr1000
Rep: sonic13 is on a distinguished road (10)
Re: Bike wont start
i have the same problem too...how did you fix it?
sonic13 is offline
View sonic13's Profile View sonic13's Gallery Find More Posts by sonic13
Old 07-17-2007, 10:22 PM
  #19
Re: Bike wont start
sorry guys been out twistn so much I haven't checked e-mail n a while.. U need 2 check all wires.. I had a loose wire underneath my ignition switch which caused the ECM.. "brain box" ..2 think that relay for fuel pump was bad.. So in the end the pump never got the power to prime r bike to start.. Cost me $180 cause I was 2 stu! stu! stupid to jus sauder the dam wire back on.. but bright enough to take pictures of it... lol... but anyway that was my problem hope my loss is your gain ...
AVIONLS is offline
Old 07-18-2007, 1:33 AM
  #20
Re: Bike wont start
what color wire was it? and which plug?
sonic13 is offline
Old 07-19-2007, 9:52 AM
  #21
Re: Bike wont start
It was a pink wire.. I belive it was about 4 wires total but only pink one was loose.. Underneath where u put key in at
AVIONLS is offline
Old 07-19-2007, 9:53 AM
  #22
Re: Bike wont start
let me no if thats it
AVIONLS is offline
Old 07-19-2007, 7:37 PM
  #23
Bike(s): 2006 CBR1000rr Black
Rep: michalis1313 is on a distinguished road (10)
Re: Bike wont start
Just purchase another one...........
michalis1313 is offline
View michalis1313's Profile View michalis1313's Gallery Visit michalis1313's homepage! Find More Posts by michalis1313
Old 07-20-2007, 12:31 AM
  #24
Re: Bike wont start
well, my ignition wires checked out ok.
sonic13 is offline
Old 07-21-2007, 3:40 PM
  #25
Bike(s): 2003 954
Rep: awood500 is on a distinguished road (10)
Re: Bike wont start
I had a similar problem with my 954. My problem turned out to be a bad ground wire. When I turned the key on no fuel pump it would crank and crank put not turn over. Then I noticed the headlight wasn't on and the turn signals didn't work. I checked the voltage with a voltmeter to find I wasn't getting a ground. I put a wire from the black wire on the headlight to the forks and like magic bike started right up. I ran through the wires and replaced one wire and bike is great again.
awood500 is offline
View awood500's Profile View awood500's Gallery Find More Posts by awood500
Old 07-21-2007, 9:23 PM
  #26
Re: Bike wont start
yea, i have heard about that problem where none of the lights work, but all my lights work fine, but i guess i'll try it anyway...
sonic13 is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:27 AM.
