F4I starts fine but runs terrible
Old 03-14-2007, 6:43 PM
Bike(s): 2002 F4I and ZX-6R
Rep: kustomheed is on a distinguished road (10)
I hope someone here can help me with this. The bike is a 02 F4I. She starts fine most of the time but then the 2 and 3 cyclinders die off. The bike sounds like a v-twin and has no pull at all when that happends. Replaces the CDI box, spedo sensor and plugs. Still no love. Any ideas would be great. Thanks
kustomheed is offline
View kustomheed's Profile View kustomheed's Gallery Find More Posts by kustomheed
Old 03-14-2007, 10:13 PM
All Gave Some & Some Gave None!
tuffy6969's Avatar
Bike(s): '03 CBR954RR
Rep: tuffy6969 is just really nicetuffy6969 is just really nicetuffy6969 is just really nicetuffy6969 is just really nice (353)
Re: F4I starts fine but runs terrible
What do you mean by "die off"? Does it happen at low speed?
"....and people in hell want ice water".
tuffy6969 is offline
View tuffy6969's Profile View tuffy6969's Gallery Find More Posts by tuffy6969
Old 03-15-2007, 11:46 AM
It happens at all speeds. Once it warms up it just runs slow. Has no quickness to it. I will have the throttle pulled all the way back and it just doesn't go. It has a hard time getting up to 40.
Old 03-15-2007, 11:50 AM
tuffy6969's Avatar
That does not sound good at all. I have a little bit of info on similar problems and what to look for. I'll get back with you after I get off of work.
Old 03-17-2007, 11:37 AM
Bike(s): 2003 CBR954RR, 1996 CBR600F3, 2001 Yamaha Jog
Rep: LITEITUP is on a distinguished road (45)
check the fuel injectors maybe?
LITEITUP is offline
View LITEITUP's Profile View LITEITUP's Gallery Find More Posts by LITEITUP
Old 03-17-2007, 11:58 AM
tuffy6969's Avatar
There could be several issues with the bike. From what you have said - here are some of the things that could cause it:
1. Ignition timing.
2. Check your ECM (computer)
3. Fuel flow & Injectors
You could have a stuck valve or bad valve timing. My recommendation would be to get it to a good mechanic (preferably one that knows Hondas) and have it checked out. It might be something simple -but my best bet is that there is something worse. Get it in right away. I wouldn't' ride it until you have it checked out first. You could be making the problem worse.
Old 03-17-2007, 12:37 PM
Sounds like its running very rich. Running cold requires a very rich mixture, but a warm engine will bog down and even die at those settings. Fuel pressure may be high or your idle adjustment may be enriching too much.
dattaway is offline
Well ya it could be pretty much anything.
LITEITUP is offline
Old 03-17-2007, 8:43 PM
tuffy6969's Avatar
NOT nice....
Old 03-17-2007, 11:08 PM
i was agreeing...
LITEITUP is offline
Old 03-18-2007, 12:58 AM
tuffy6969's Avatar
i was agreeing...
Oops....
Old 03-19-2007, 11:36 PM
Bike(s): 2004 Honday CBR600F4i
Rep: redneckF4rider is on a distinguished road (10)
I had a problem that was very similar...I changed plugs and three out of four injectors....bike runs like a champ...word of advice, never use regular unleaded fuel, and add some injector cleaner ever so often!!! It helps!!
redneckF4rider is offline
View redneckF4rider's Profile View redneckF4rider's Gallery Find More Posts by redneckF4rider
Old 03-23-2007, 11:24 PM
Bros, thanks for the ideas. I took it to the Honda shop and it was the fuel pressure regulator. It wasn't flushing fuel back to the tank and it just sat in the motor. It was flooding the center two cyclinders. What a pain. But $300 later and the bike runs like new. Well, better then new. I put on a Yosh Tri-oval and it sounds mean. Keep it on it tire!!! Later
Old 03-24-2007, 9:29 AM
tuffy6969's Avatar
Well - I'm glad you got it fixed. I know it sucks not knwoing what's wrong with your bike!
Old 03-25-2007, 2:43 AM
  #15
Bro, the thing is that if I knew it was as simple as the fuel regulater, I could have don't that myself. With all the problems I have had with this bike and then the tinkering with my other bike.... I have a vault full of "what could be wrong with my bike" tips.
Old 03-25-2007, 2:02 PM
  #16
tuffy6969's Avatar
I understand that. Unfortunately, most of us don't have the sophisticated training and equipment most modern shops use to diagnose problems with. There was a day when they had to diagnose by process of elimination. Now, with all the bikes being EFI and having computers on board, they just plug something in and get a diagnosis. They still use process of elimination once in a while, but by far, it's easier to diagnose now then it was then.
Old 03-25-2007, 8:36 PM
  #17
I've found even with all the computer controlled devices, its still possible to look. listen, and smell. Those three senses with the help of a voltmeter and screwdriver are able to troubleshoot almost all problems.
dattaway is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:59 PM.
