bike wont start pls help!!
Old 03-21-2007, 11:23 AM
Bike(s): 1998 cbr f3
Rep: cduvelius is on a distinguished road (10)
the other day i ran the reserve out of gas to get the gas tank off. i put it back on turned the gas on and now the bike wont start. it turns over but wont start. it has gas the spark plugs are firing and i dont know what else to try. has anyone else experienced this? what should i do?
cduvelius is offline
View cduvelius's Profile View cduvelius's Gallery Find More Posts by cduvelius
Old 03-21-2007, 1:43 PM
Bike(s): CBR 600F4I
Rep: trtlpmp is on a distinguished road (10)
Re: bike wont start pls help!!
Per the repair manual, here are some causes:
Intake air leak
Fuel contaminated/ or deteriorated
Pinched or clogged fuel tube
Faulty fuel pump
clogged fuel filter
Clogged fuel injector filter
Sticking fuel injector needle
Faulty fuel pump operating system
trtlpmp is offline
View trtlpmp's Profile View trtlpmp's Gallery Find More Posts by trtlpmp
Old 03-21-2007, 1:53 PM
Toggle the ignition switch a few dozen times to "bump" the fuel pump and fill the carbs. Its a diaphram type.
It won't start running continuously with the engine off as a safety feature.
dattaway is offline
Old 03-21-2007, 3:36 PM
i toggled the throttle many times and it wouldnt start so i took the air filter off and dumped a little gas in the things under the filter and it still wont start. i thought i flooded the **** out of it so i turned the gas off and let it sit overnight and tryed in the morning...morning came and still nothing. it was working fine before we ran the reserve out. i have no idea what to do next.
Old 03-21-2007, 3:45 PM
rokitt51's Avatar
Rep: rokitt51 is on a distinguished road (30)
Is the pump connected and working properly? Check the fuses. Use some ether in the ait intake. Ether will always cause a fire.
rokitt51 is offline
Old 03-21-2007, 3:52 PM
how would i know if the pump is working? wheres it at? how to test it? so spray carb cleaner in the air intake? ill try that thanks
Old 03-21-2007, 6:42 PM
well all the fuses are good
Old 03-21-2007, 7:25 PM
i just checked the fuel pump and its working fine.. what should i do now?
Old 03-21-2007, 9:47 PM
Are the carbs full of fuel? If not, there's a fuel line from them to the fuel pump. Something's keeping it from getting in your engine.
dattaway is offline
Old 03-22-2007, 2:10 PM
well i finally got it started thanks for all the help everybody. i was spraying carb cleaner in the carb and then i busted the fuel line so i had to take the tank off and go buy another line. then i decided to try to start it with the carb cleaner again so i opened the throttle up and sprayed cleaner in all of them. then the straw fell into the carberator so i had to take the carberator apart just to get the damn straw out. i got the straw out and tryed to start it and it started for a couple seconds so i put the tank back on and now it starts. hell i dunno what the problem was but it turned out to be a pain in the ass. im just glad i finally got it started. thanks everyone
Old 03-22-2007, 2:28 PM
You saved that poor little straw from certain destruction! As a kind token of its gratitude, the grateful straw fixed your bike.
dattaway is offline
Old 03-25-2007, 4:23 AM
Bike(s): 2002 F4I and ZX-6R
Rep: kustomheed is on a distinguished road (10)
I don't know if this will help but maybe it will save you some ass pain in the future but since you were trying all those things to start the bike I would pull the plugs and clean them off. The excess fuel could have burned off and it might not be a problem but next time you have the tank off save your self some future fustration and clean the plugs.
kustomheed is offline
View kustomheed's Profile View kustomheed's Gallery Find More Posts by kustomheed
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 11:46 PM.
