i know i know my bike wont start
03-27-2007, 11:33 PM
Bike(s): cbr f4i 600 red, red wheels Posts: 20
| i know i know my bike wont start i have a 02 f4i 3500 miles, i ran out of gas the other day go some body to bring me some gas i put it in it, it crank back up fine, i drove to the gas station and filled it up, it cranked up fine then pull out of the parking lot it started dieing so naturally i gave it some gas and then it died and hasnt crank since, i will turn over fine it just wont catch
ive took on one of the spark plugs out it was sparking fine, the fuel pump is working fine, i took the gas line off at the fuel log that feeds the injectors and it was getting fuel, i just dont understand what the problem could be, any help would be great thanks |
03-30-2007, 11:45 PM
| Re: i know i know my bike wont start well i assume nobody here can tell me what my probelm, i guess ill be on my way to 75.00 an hour at the honda shop |
03-31-2007, 12:48 AM
#3 | | 2-Up SISSY
Bike(s): 2002 CBR 600F4i / 2003 XR650R 'Tard Age: 29 Posts: 2,596
| Re: i know i know my bike wont start Check your fuses.
03-31-2007, 11:08 AM
Bike(s): '01 CBR929 Age: 49 Posts: 8,012
| Re: i know i know my bike wont start Bad gas? Or worse...you filled it with diesel.
03-31-2007, 12:30 PM
Bike(s): f4i, f2, zx6r, gsxr Posts: 74
Rep:  (12) Rep Power: 2
| Re: i know i know my bike wont start from running dry could have sucked dirt up and got in injectors. Try cleaning ther throttle bodies up before you pay a dealer, or drain the tank and fill w/ fresh gas and maybe injector cleaner |
03-31-2007, 2:01 PM
Bike(s): 2003 CBR954RR, 1996 CBR600F3, 2001 Yamaha Jog Age: 26 Posts: 509
Rep:  (45) Rep Power: 3
| Re: i know i know my bike wont start Yeah that "somebody" might have gave you diesel or kerosene or somethin crazy. And what HiLi_Psyclez said. |
04-01-2007, 1:38 AM
| Re: i know i know my bike wont start nah it cranked up fine when he brought me a little gas back, but after i filled up it, didnt run, i know for sure that i got 89 test gasoline in it, wether that gas was shitty or not iam not sure it was just a local little gas station in the middle of no where , but thanks for the replys
oh yea ive checked the fuses to |
04-02-2007, 8:59 PM
| Re: i know i know my bike wont start replaced the spark plugs, we sprayed some either in the air intake and it fired, so there for i know iam getting fire, just not fuel, and iam getting fuel to the fuel log
maybe fuel injector needle is stuck?? |
04-03-2007, 1:44 PM
Bike(s): 01 Aprilia SL 1000 Falco & 94 600 F234i Conversion Posts: 119
Rep:  (11) Rep Power: 3
| Re: i know i know my bike wont start It sounds like the electronics that run your injectors are not working. I think that box is separate from your ignition box but driven by the same map electronics. You might double check the fuses or start looking for a broken wire. |
