Need help, bike is only transportation.
04-10-2007, 11:00 AM
Bike(s): CBR 600F4I Posts: 29
| Need help, bike is only transportation. When I turn the bars all the way to the left or right, it makes a clunking sound. I have no idea what it could be, and I'm pretty worried because if my bike goes down, I have no way to work.  |
04-10-2007, 11:06 AM
Bike(s): 2002 CBR600F4i Age: 26 Posts: 3,876
Rep:  (98) Rep Power: 0
| Re: Need help, bike is only transportation. head bearings? |
04-10-2007, 11:08 AM
| Re: Need help, bike is only transportation. Where are those? How bad is it? What are some of the possible causes? |
04-10-2007, 11:17 AM
| Re: Need help, bike is only transportation. One that may not be the cause, the manual says you can hear noise if the forks are low on fluid (not sure what kind of noise, just says noise).
Is the steering stiff? does the bike pull to one side or another doing down the road? Maybe this will help point us in the right direction. |
04-10-2007, 11:22 AM
| Re: Need help, bike is only transportation. Nothing wobbles, bike drives straight. No bar vibration......Not hard to steer. Just a clunking noise, but it has to be turned all the way to the point where it stops to make the noise. |
04-10-2007, 11:39 AM
Bike(s): f4i, f2, zx6r, gsxr Posts: 74
Rep:  (12) Rep Power: 2
| Re: Need help, bike is only transportation. see if the head bolt is tight, mine made a clunk before when id brake hard ended up being hte nut ont he top triple was loose. Id check that or like sinful said possible bad bearings if the nut is tight. Check the lock nuts under the triple also.
First thing i always do w/ clunks or noises like that is check for loose bolts, these badboys vibrate alot so .. good idea to go over the bolts once a month or so. I always find at least one bolt/nut loose everytime i do. |
04-10-2007, 11:42 AM
| Re: Need help, bike is only transportation. When are you riding that you need to turn the bars all the way.
just to ask a stupid question and get it out of the way... did you install clipons that are maybe hitting the frame or something when turned all the way? |
04-10-2007, 12:09 PM
| Re: Need help, bike is only transportation. No, that's a fair question.
When I'm backing up. Still have the stock bars on. |
04-10-2007, 12:13 PM
| Re: Need help, bike is only transportation. Quote:
Originally Posted by trtlpmp No, that's a fair question.
When I'm backing up. Still have the stock bars on. | In that case start with HiLi's suggestion and check that bolt over the main bearings. If thats not loose, thats my bet of whats wrong. Also as he pointed out if you grab the front breaks and stop hard you will probably hear that same noise from there if there is an issue |
04-10-2007, 9:23 PM
Bike(s): '01 CBR929 Age: 49 Posts: 7,695
| Re: Need help, bike is only transportation. You need to raise the front end up and wiggle it to try and locate the source. It could be several things causing the noise...steering head, brake caliper, rotor, etc.
04-11-2007, 2:30 AM
Originally Posted by sinfuldragon In that case start with HiLi's suggestion and check that bolt over the main bearings. If thats not loose, thats my bet of whats wrong. Also as he pointed out if you grab the front breaks and stop hard you will probably hear that same noise from there if there is an issue | Tried braking hard, no noise. Checked the bolt, it's tight. |
04-11-2007, 2:31 AM
Originally Posted by Red Rider You need to raise the front end up and wiggle it to try and locate the source. It could be several things causing the noise...steering head, brake caliper, rotor, etc. |
Like put some straps around the bars and over a beam? |
04-11-2007, 7:13 AM
#13 |
Originally Posted by trtlpmp Like put some straps around the bars and over a beam? | Or just be a man and pick it up with your bare hands.... the choice is yours |
04-11-2007, 8:14 AM
#14 |
Originally Posted by trtlpmp Like put some straps around the bars and over a beam? | No, you don't want a direct load on the front end. You want it to be unloaded so you can check the movement freely and listen for any sounds. A front stand that lifts by the steering stem hole will work. You could also try running a strap under the steering head and lifting it from there...carefully.
04-11-2007, 10:41 AM
#15 |
| Re: Need help, bike is only transportation. or have a buddy rock the bike back onthe kickstand if you dont have another way to unload the front. Like redrider said it could be a caliper or a few other possibility if it isnt the stem nut. Front wheel bearings??? |
04-15-2007, 4:40 PM
#16 |
| Re: Need help, bike is only transportation. Okay, I found out what it was. First of all, thank you to everyone who replied. The front axle bolt was loose. First I loosened everything up, then re-tightened everything per the manual, and took it for a test ride. No more "clunck". |
04-15-2007, 4:58 PM
#17 | | 2-Up SISSY
Bike(s): 2002 CBR 600F4i Age: 29 Posts: 2,437
Rep:   (168) Rep Power: 5
| Re: Need help, bike is only transportation. I think that is almost scarier than finding the head bolt loose. I try to check all of my bolts every so often but I might increase that frequency now.
04-16-2007, 12:22 PM
#18 |
| Re: Need help, bike is only transportation. glad you caught it bro, were the pinch bolts still tight?
These things vibrate, i try to go through all my bolts pretty often, always find a few loose ones. never an axle though lol. |
04-26-2007, 4:44 PM
#19 |
Originally Posted by HiLi_Psyclez glad you caught it bro, were the pinch bolts still tight?
These things vibrate, i try to go through all my bolts pretty often, always find a few loose ones. never an axle though lol. | Yeah, they were tight. Tight enough, I don't know. |
