oil change on a 2004 CBR 600 F4i...
04-15-2007, 2:00 AM
Bike(s): 2007 Honda CBR 600 RR Age: 56 Posts: 96
Rep:  (32) Rep Power: 3
| oil change on a 2004 CBR 600 F4i... i am thinking that i may tackle changing oil on my 2004 CBR600F4i the next time it needs it, rather than take it in to the mechanic. what i would like to know is whether it is possible to remove the filter without removing the farings. the manual says to remove the farings however, when i was detailing my bike today i could see the filter in plain site and was thinking that maybe it is possible to get remove it without removing the farings. thanks in advance to anyone who can share some knowledge on this. i appreciate it. |
04-15-2007, 10:16 AM
Bike(s): 2006CBR 600f4I Age: 57 Posts: 47
| Re: oil change on a 2004 CBR 600 F4i... I wrapped the headers with Aluminum foil to keep oil off of them. Then just remove filter then replace with new one I lube the gasket on the new filter with a little oil. |
04-15-2007, 10:50 AM
Bike(s): f4i, f2, zx6r, gsxr Posts: 74
Rep:  (12) Rep Power: 2
| Re: oil change on a 2004 CBR 600 F4i... yea f4i's are easy to change the oil/filter in w/out removing anything. I bought the oil filter wrench (goes on 3/8 ratchet) and i use a 6" extension works great. I usually buy the oil in the gallon containers, it takes most of it and saves a little money, plus after a few oil changes you have enough leftover to do another one. |
04-15-2007, 10:55 AM
| Re: oil change on a 2004 CBR 600 F4i... thanks for the great tips. what is the torque setting for tightening the oil filter? and, is that oil filter wrench easy to find? i am definitely going to do this myself the next time. you guys have given me the confidence i needed. |
04-15-2007, 1:03 PM
Bike(s): 2002 CBR600F4i Age: 26 Posts: 3,876
Rep:  (98) Rep Power: 0
| Re: oil change on a 2004 CBR 600 F4i... should be able to find it at your local walmart, if you use K&N then there is a nut welded on it so no filter wrench is needed.
tighten oil filter just like a car. until the seal hits the metal then I think a quarter or half turn past. |
04-15-2007, 1:46 PM
| Re: oil change on a 2004 CBR 600 F4i... thanks sinfuldragon. i appreciate it. |
04-15-2007, 2:09 PM
Bike(s): '01 CBR929 Age: 49 Posts: 7,695
| Re: oil change on a 2004 CBR 600 F4i... Not sure about an '04, but the torque setting for the '03 F4i oil filter is 20 lbf.ft. Improperly fastening an oil filter is asking for trouble...
04-15-2007, 6:54 PM
#8 | | 2-Up SISSY
Bike(s): 2002 CBR 600F4i Age: 29 Posts: 2,437
Rep:   (168) Rep Power: 5
| Re: oil change on a 2004 CBR 600 F4i... I bought the "exact" oil filter wrench from the dealer. It comes with an oil filter for about $20, so I guess you are paying about $10 for the wrench. I personally give it a good recommendation and I always use a torque wrench on it.
04-15-2007, 7:16 PM
| Re: oil change on a 2004 CBR 600 F4i... you guys have been a great help. i definitely want to get one of those wrenches. |
04-16-2007, 12:38 PM
| Re: oil change on a 2004 CBR 600 F4i... yea i got mine from the dealer for $8 i think it was i always use the oem honda filters. Never had a problem w/ my bike honda gn4 and oem filter since day one so not gonna change a good thing lol. |
02-10-2008, 9:35 PM
Bike(s): 04 cbr 600 f4i Posts: 2
| Re: oil change on a 2004 CBR 600 F4i... I just checked the manual for a 2004 f4i, it states to tighted oil filter to 20 lbf and tighten the drain bolt to 22 lbf.  |
