05-13-2007, 9:55 AM
Bike(s): 2002 CBR F4i Age: 30 Posts: 20
| 2002 F4i not starting Help, I was out riding ran fine ,got gas and now it wont start ,fuel pump doesn't prime ,no headlights,and all lights on dash stay on,fuses are all good ,turns over just fine.  |
05-13-2007, 9:57 AM
Bike(s): 2002 CBR600F4i Age: 26 Posts: 3,876
Rep:  (98) Rep Power: 0
| Re: 2002 F4i not starting no headlight and fuel pump doesn't prime, but gauge lights work and the starter turns the engine over... are you sure you checked all the fuses? |
05-13-2007, 10:06 AM
| Re: 2002 F4i not starting yes fuses are all good ,might stick all new ones in right now i'm up for anything |
05-13-2007, 10:14 AM
| Re: 2002 F4i not starting Do you have a wire tester to see if voltage is getting to your fuel pump (if there is than the pump is dead but that wouldn't really explain the headlight now would it....).
If you turn the key to run or start or whatever the hell where the fuel pump should normally prime and just leave the bike on the side stand, watch the lights to see if any start blinking. If they do its sending you an error code. a long blink is = to 10 and a short blink is equal to 1. so one long blink and three short would be code 13. If its sending one post it and I'll look it up for you. |
05-13-2007, 10:43 AM
| Re: 2002 F4i not starting I turned key on for 5min no code ,its strange turn lights on dash stay on and signals dont work,high beam light stays on even if I flip switch,the only light thats not on is the FI light , I hate electrial problems ! |
05-13-2007, 10:46 AM
| Re: 2002 F4i not starting Sorry bud, we all do. Hopefully someone will chime in with a good suggestion soon. |
05-13-2007, 3:05 PM
| Re: 2002 F4i not starting I pulled tank off and the plug that goes to fuel pump has 12volts to it,plug has 3 wires ground, hot,not sure what 3rd wire is does it send signal somewhere to a relay maybe?? |
05-13-2007, 5:19 PM
Bike(s): '01 CBR929 Age: 49 Posts: 7,695
| Re: 2002 F4i not starting Check and clean the kill switch...look for corroded terminals.
05-13-2007, 7:53 PM
| Re: 2002 F4i not starting I traced wiring from computer to relays tofuel pump and up through to dash for my reserve lite even checking wires with multimeter cant find any broken or corroded wires I'm done for tonite talk with dealership tommarrow . I will stay with hvac and let them work on thebikes unless they have a good idea. thnks for the help , also this is a cool site |
05-14-2007, 7:12 PM
| Re: 2002 F4i not starting If there is anything out of the manual that you would like to see just let me know and I'll post the page(s) up here for ya.
If you jump start the bike will it start? |
05-14-2007, 9:38 PM
| Re: 2002 F4i not starting the bat. is charged ,However I did try to pop start it in 2nd gear , nothing ?? thank for offering to post some pages out of the manual but I took it to the dealer Icalled around for one to day no one has them need to order them and I need to get her back on the turns for a trip to Tenn. in june .Guess I cant complain to much 1st thing wrong with bike in 24,000 and I bought it new. |
07-14-2007, 8:54 PM
Bike(s): 04 cbr 600 f4i Posts: 1
| Re: 2002 F4i not starting hey not sure if you figured this prob out yet..had same prob with my 04 f4i..under the front cowl is a large(1 inch by 1/2 inch)grey wire connecter.in this wire connecter,try and push the wires together and see if this corrects the problem...on my bike the connection on a green wire was bad thru the connecter....i wired around it and has worked fine for almost 2000 miles since..injected bikes are backwards wired,this green wire is a ground,if it isnt making a good connection then nothing recieves a good ground...still recieves power, but not a good ground....hope this helps!!chris |
07-16-2007, 6:27 PM
#13 |
| Re: 2002 F4i not starting Yea I couldn't figure It out so I took it to the dealer and they got it running for 250.00$ and didn't tie any wires back where they belong just left them hanging against the forks I was a little hot!  They were rubing the forks on the way home I had to rip it all apart when i got home.  It kind of sounds like the same plug it was just coroided ,think it was the only plug I didn't look at. I don't think they will touch my bike again they cant even put it the way they found it. |
