cbr 600 fw (98)
Old 05-23-2007, 7:10 AM
Bike(s): cbr 600
Rep: SteveC is on a distinguished road (10)
cbr 600 fw (98)
Hi.
I bought an engine off ebay a few months ago, its off a cbr 600 fw (1998), since then ive been searching round for other bits and bobs to help get it running. I eventually want to stick the engine in a small chassis and make it into a nice and fast kart.
Just a few questions to start off with, what temperature does the engine usually like to run at?
What is the area of the radiator?
I would like to know the area of the radiator as i was thinking of getting a small car's radiator and using that rather than an expensive 2nd hand cbr radiator, plus the cbr ones are bent into a 'v' type shape, i wanted a flat one.
On my bike, there are the 2 hose connections (25mm) to go to and from the radiator, but there are also another 2 small hoses (approx 6mm internal diameter), im not sure where these lead to and what they do?
I can get some pictures and show you the ones which i mean if you like?
I think one comes from the water pump and one from the thermostat area (could be wrong though).
Do i need to have anything connected to the small air pipes on the carbs? (Where the solenoids and small air box things go)
Any help / advice would be much appreciated.
Thanks.
Steve
SteveC is offline
View SteveC's Profile View SteveC's Gallery Find More Posts by SteveC
Old 05-23-2007, 5:33 PM
Bike(s): 2001 CBR 929rr
Rep: Triax is on a distinguished road (16)
Re: cbr 600 fw (98)
Holy crap batman! could you ask a few more questions. Take a look at a parts fische that will help you out a lot.
Triax is offline
View Triax's Profile View Triax's Gallery Find More Posts by Triax
Old 05-23-2007, 10:35 PM
Bike(s): 2002 CBR600F4i
Re: cbr 600 fw (98)
He sure asked a couple didn't he.
the small hoses... if its like my 02 F4i then the small one by the top radiator hose (there are actually two there) one runs to the coolant tank (up by radiator cap)and the other is an "air bleed hose" looks to go into the thermostat housing
the one on the other side with the lower radiator hose is the Oil Cooler Water Hose and it runs to the water pump.
Not sure of the size of the radiator but it and the engine will hole 2.9 quarts if that helps at all
sinfuldragon is offline
Old 05-24-2007, 6:45 PM
Bike(s): cbr 600
Re: cbr 600 fw (98)
thanks for the replies, ive re-read my haynes manual and i think that the 2 small hoses go to the carb's.
One is directly from the water pump, the other goes through the thermostatic valve (its sort of bolted to my starter motor). Im not sure which way round they go onto the carbs, but i guess it doesnt matter too much since water will flow between them either way.
Sorry to be a silly billy, but i dont know what a fische is, lol.
I guess for the radiator i might as well get a small car one, or ive seen a nice alloy one on ebay for about £30 ($60).
How many hoses connect to the reservoir tank?
I guess the engine temp is ok if the needle is sat between the min and max marks on the clock.
SteveC is offline
Old 05-26-2007, 7:44 PM
Bike(s): cbr 600
Re: cbr 600 fw (98)
can anyone tell me the approximate dimensions of the cooling part of the radiator please?
SteveC is offline
Old 05-26-2007, 11:22 PM
Re: cbr 600 fw (98)
If you would like tomorrow I can go out and measure my radiator from side to side and top to bottom. Not sure what the "cooling part" is though.
PM me if you want me to do so. This way I don't have to try to hunt through threads to see the answer (yes I'm lazy)
Old 05-28-2007, 2:53 PM
Bike(s): cbr 600
Re: cbr 600 fw (98)
by cooling part i meant the area which air goes through, not the surrounding frame.
SteveC is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:25 PM.
