Engine runs hotter than normal
Old 06-19-2007, 4:17 PM
Bike(s): CBR 600F4I
Rep: trtlpmp is on a distinguished road (10)
Last week my thermostat switch went out, so I replaced it, along with new antifreeze. Now my bike runs hotter than normal. I usually run in the 180s on the Hwy. Now my bike runs from the 190s and up into the 200s. Any ideas?
trtlpmp is offline
View trtlpmp's Profile View trtlpmp's Gallery Find More Posts by trtlpmp
Old 06-19-2007, 4:49 PM
Bike(s): 2002 CBR600F4i
Re: Engine runs hotter than normal
did you burp the system after changing the coolant?
My bike sees these temps all the time. I can get it to 200 depending on how I'm riding down the highway. If I ride normal it will sit anywhere between 180 and 190 depending on the outside temp
sinfuldragon is offline
Old 06-19-2007, 6:00 PM
Bike(s): CBR 600F4I
How do I burp the system?
My bike usually runs high 170s to 180s. I don't see 200 unless I'm sitting at a light.
trtlpmp is offline
Old 06-19-2007, 6:51 PM
Bike(s): CB400SF,
Rep: Paddy is on a distinguished road (10)
There can be air in the cooling system.When you filled it did you squeeze the
hoses to get the air out.
What coolant did you put in the bike and did you mix 50/50 water.
Paddy.
Paddy is offline
View Paddy's Profile View Paddy's Gallery Find More Posts by Paddy
Old 06-19-2007, 6:57 PM
Bike(s): CBR 600F4I
No, I didn't squeeze any hoses. I used a 50/50 premixed antifreeze from my local moto dealer.
trtlpmp is offline
Old 06-19-2007, 7:17 PM
Bike(s): CB400SF,
If there is air in the system then the coolant will not be cooling all that it
should be as air will be where coolant should be.
Take off the cap and move the bike left and right and sqeeze the hoses to get
the air out.
Paddy.
Paddy is offline
Old 06-19-2007, 7:38 PM
Bike(s): CB400SF,
I am not sure how to edit but only take off the cap when the bike is cool and
not hot.
Paddy.
Paddy is offline
Old 06-20-2007, 6:07 PM
Bike(s): CBR 600F4I
The bottom hose, the top hose, or all the hoses?
trtlpmp is offline
Old 06-20-2007, 11:40 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (799)
All. It's easy, I just changed my coolant last weekend. Leave the cap off, and squeeze all the hoses a couple times while the bike is idling. Also blip the throttle, too...
Red Rider is offline
Old 06-21-2007, 12:27 AM
Bike(s): CBR 600F4I
Cool thanks! I'm assuming I need to top off the coolant in the radiator.
trtlpmp is offline
Old 06-21-2007, 8:20 AM
Red Rider's Avatar
Bike(s): '01 CBR929
Yes, after any air is purged fill it back up to the top.
Old 06-22-2007, 1:47 PM
Bike(s): CBR 600F4I
Bike runs nice and cool again. Thanks fellas!
trtlpmp is offline
Old 06-26-2007, 9:21 AM
Bike(s): 2001 CBR F4I Red White and Black.
Rep: wander81 is on a distinguished road (10)
I'm new to the whole DIY maintance and my bike was running a little hot too. I was wondering can I just put any 50/50 premix coolant in there? And how do you put the coolant in there? I ride a '01 CBR 600f4i
wander81 is offline
View wander81's Profile View wander81's Gallery Find More Posts by wander81
Old 06-26-2007, 11:51 AM
Bike(s): CBR 600F4I
Pick up some coolant from your local Motorcycle dealer/shop. I used one called Engine Ice, it works great now. My bike runs 10 degrees cooler than it was. As far as putting the coolant in, (at least with my bike), all I have to do is remove the right side faring, and use a funnel.
trtlpmp is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 4:57 PM.
