charging system?
Old 06-21-2007, 7:26 AM
Bike(s): 1997 f3 600
Rep: brianb112 is on a distinguished road (10)
charging system?
I have a 1997 cbr 600f3. It runs ok on a fully charged battery for 2 or 3 days, after that it stalls out and wont start again with the start button. It will start when i run it down the road and drop it into 2nd gear, but doesnt stay running for more than a minute. I put a new battery in it, but it does the same after 2 days. When i charge the battery for 10 minutes, it fires up again. Could it be the charging system?
brianb112 is offline
View brianb112's Profile View brianb112's Gallery Find More Posts by brianb112
Old 06-21-2007, 7:31 AM
Bike(s): 01 929RR, 99 900RR, 01 600F4i
Rep: Atreyu will become famous soon enough (65)
Re: charging system?
sounds like you have either a bad stator or Reg/ Rec, or both are bad....in other words the alternator isn't charging the battery
Atreyu is offline
View Atreyu's Profile View Atreyu's Gallery Find More Posts by Atreyu
Old 06-21-2007, 7:58 AM
Thats what i thought. One question which i havnt noticed because i just bought it last year and had no problems, but do you know if its fuel injected. I ididnt notice a carb, but im not home now. This would explain it just cutting out.
Old 06-21-2007, 12:36 PM
it's carbed
Atreyu is offline
Old 06-21-2007, 3:03 PM
Bike(s): CB400SF,
Rep: Paddy is on a distinguished road (10)
Check the voltage across the battery with the ignition off.It should be 12+.
Check it with the engine running and 3500 rpm.It should be 13.5 or so.
If it is 12 volts or less then I would change the reg/rec.
I would not expect the stator to fail.
Paddy.
Paddy is offline
View Paddy's Profile View Paddy's Gallery Find More Posts by Paddy
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:04 AM.
