08-25-2007, 2:58 PM
Bike(s): honda CBR F2 600 Posts: 16
| I NEED HELP NOW hey every 1 im a new ride'er less than i month. with the problem im haveing i think my rideing day are over. its not worth the sterss so im hopeing someone here can help me so i dont kick over the bike and lite it on fire lol. now whan i got the bike it sounded like crap so i took a look and found out the plug on the 2nt carb was missing. i put one on and synchroniz'ed the carbs and it was runing realy nice for liek a week. than the batrry kept going dead so i got a new one. so whan i was rideing one day it die'ed while moveing. i try'ed to start it there was nothing so i knew the battry was dead agean. i charged it and was it was runing i pulled off the + battrey cable and it die'ed. i kenw it was runing off the battrey checked the regulater/recyifier and it was not reading right so i went and got a new one. it started right up i pulled off the + cable and it stayed runing so i look it out for like an hour and it was fine. the next day i went to start it and the battery was low so i charged it and whan running took off the + battrey cable agean it die'ed ........ so now i dont know what to think its realy geting to me and i hope i dont have to get a ew regulater and alltnater becoues that $$ i realy dont have to spend it any one know andthing about it please let me know |
08-25-2007, 5:53 PM
Bike(s): cbr600 f3 bmw steelgray Posts: 20
| Re: I NEED HELP NOW my f3 did almost the same thing. I forgot the name of the part but it was the little computer box attached to the frame when you remove the tail fairings |
08-25-2007, 7:10 PM
| Re: I NEED HELP NOW ya thats the regulater i also found out that the clip for it is gone so its jsut wire's so i may have put the 3 yellos on roung ill take a look if anyone els has any ideas plaese let me know |
08-25-2007, 8:05 PM
Join Date: 05-28-2007 Location: SW Ohio "Buckeye Country"
Bike(s): '03, CBR954RR; Titanium & '04 CBR600RR; Blue Age: 39 Posts: 513
Rep:  (32) Rep Power: 2
| Re: I NEED HELP NOW Tom, Don't throw in the towel yet, although these types of things can be frustrating to go through; it's not an uncommon experience when you first start out to have to deal with this type of stuff. It does have the benefit of helping you to develop your debug / investigative skills which will be valuable all of your life. Once you get to a point that you can afford newer bikes that you typically won't have many problems with, you will still be able to use the skills and experience you gain from having older, more problematic bikes by helping out your friends that get in the position you were in early in your riding career. Take a deep breath, and keep in mind this old adage "throughout history, millions of people have survived far worse situations than you have right now, and they lived to tell about it" so don't sweat it bro, things will get better. |
08-29-2007, 2:13 AM
Bike(s): 01 Aprilia SL 1000 Falco & 94 600 F234i Conversion Posts: 106
Rep:  (11) Rep Power: 2
| Re: I NEED HELP NOW F2's are notorious for problems like this. For starters, make sure you keep both battery cables tight at all ends. A loose positive cable can cause many of the problems you describe by causing the regulator/rectifier to fail, which typically causes it to overcharge and thus ruins the battery. The end result is a bike that frequently needs recharging (especially when low RPM's are frequent) or it might explode underneath you like mine did (50 miles out in the mountians ). The stock reg/rect can barely power the high beam at 4000 rpm so avoid them if they dont havea HUGE heat sink!!!! So there, the bad news is out of the way. Also, the F2 and many sport bikes electrical systems are powered from the battery and not the charging system like a car. I'm really suprised your bike kept running when you pulled the +12v cable as it shouldnt have... this might be insight to a shorting Reg/Rect again as that might overcharge and cause the system to stay running.
The good news is that a high quality reg/rect ($90) with the huge metal cooling fins can power two H4 bulbs and accessories while putting around all day if the rest of the system is in good shape. |
08-29-2007, 2:31 PM
| Re: I NEED HELP NOW thanks allot .... I went threw the alternator wires and when I got to a clip I found it was melted and burnt so I think that’s my problem so im getting another one and another regulator I hope that’s the end of it |
08-30-2007, 8:42 AM
Bike(s): cbr1000rr in rattle can black Age: 39 Posts: 903
Rep:  (75) Rep Power: 4
| Re: I NEED HELP NOW Quote:
Originally Posted by SoCal94F2 The stock reg/rect can barely power the high beam at 4000 rpm so avoid them if they dont havea HUGE heat sink!!!! | You won't believe this, but the regulator/rectifier will run COOLER with the high beam on. Its not a linear type regulator. Its a zener/SCR type. It shunts all unused power back to the coils. The coil runs hot all the time, if its used or not. |
08-30-2007, 11:08 AM
| Re: I NEED HELP NOW Yep, completely agree. I only make big deal about the Huge heat sink so that people dont buy the cheap one and continue having problems. The high beam doesnt require more voltage, but more amperage. The problem with the stock design is the regulation where excess voltage is shorted off, which generates heat, which the stock regulator doesnt dissapate well. The only good thing about buying a $25 cheap one is having a backup reg/rect stored on the bike... just in case!
08-30-2007, 11:32 AM
#9 | | 2-Up SISSY
Bike(s): 2002 CBR 600F4i Age: 29 Posts: 2,533
Rep:   (190) Rep Power: 5
| Re: I NEED HELP NOW Quote: |
| Have a part number? I'd like to file it away for future reference since I've heard that having them go is almost as certain as death, taxes, and F4i CCT problems. I have no problem with paying for a good one.
08-30-2007, 1:20 PM
| Re: I NEED HELP NOW I bought mine on ebay for a little over $100 but you can get them other places as well. The japanese manufacturer is escaping me at the moment with a part number of sh693-12 . I cant rave enough about this one in particular as it allows me to run additional lighting and accessories without ever having a discharge anymore (was a huge problem with other reg/rects). I almost went down the path of a heavy duty stator but now know the stock one is more than enough. I've heard that honda has a stock replacement that is different now which also has a heat sink and that they fail less frequently than stock but cost the same as the one above.
The box looks like this: http://i6.ebayimg.com/03/i/04/67/00/e7_1_b.JPG |
09-02-2007, 8:09 PM
| Re: I NEED HELP NOW thas man i took you advice and got the heavy duity one and im so happy to be rideing agean thanks alot |
09-02-2007, 9:14 PM
Bike(s): XX, RC51, '08 1000RR LE Posts: 1,377
Rep:  (44) Rep Power: 4
Originally Posted by slickwill Have a part number? I'd like to file it away for future reference since I've heard that having them go is almost as certain as death, taxes, and F4i CCT problems. I have no problem with paying for a good one. | Try Electrex USA if you don't want to deal with the eBay hassle. I think they have changed their name though. You will probably pay a few extra bucks but at least you know you will get it and that it is new. Not to mention, you know they will help and who to call. |
09-02-2007, 11:25 PM
#13 |
Originally Posted by TomMac thas man i took you advice and got the heavy duity one and im so happy to be rideing agean thanks alot |  Ride on! |
