Air Filte Help
Old 09-18-2007, 8:11 AM
Bike(s): 2006 Honda CBR 600RR
Rep: fozzy_lee is on a distinguished road (10)
Air Filte Help
I was wondering if some one can tell what all I need to take off my bike to get to the air filter. I already know that the tank cover and tank need to be lifted up but is there any fairings that need to come off with it?
fozzy_lee is offline
View fozzy_lee's Profile View fozzy_lee's Gallery Find More Posts by fozzy_lee
Old 09-18-2007, 8:16 AM
The track is the place to be
Gecko5's Avatar
Bike(s): 03 600RR
Rep: Gecko5 is on a distinguished road (14)
Re: Air Filte Help
You'll probably have to remove the ram air covers before taking the tank cover off. They are attached via a screw to the mid-fairing, "peg-n-"hole" to the upper fairing, and two tabs to the tank cover (which probably could be left alone). You might also have a push pin that attaches to the ram tubes from inside by the forks.
Gecko5 is offline
View Gecko5's Profile View Gecko5's Gallery Find More Posts by Gecko5
Old 09-18-2007, 8:20 AM
Re: Air Filte Help
Thanks. That helped alot
Old 09-19-2007, 11:28 AM
Gecko5's Avatar
Bike(s): 03 600RR
Re: Air Filte Help
I was think some more and you will need to take the seat off and remove the seat bracket (black cross member that is attached with four bolts and nuts) this way you will be able to tip the tank up and give you some more room to work. The front two tank anchor bolts should be enough and slowly lift the tank because there are hoses below the tank that might need some help.
As for holding the tank up you can run a bungie from the front part of the tank to the anchor that holds the pass seat down.
Taking the seat off too will give you access to the two bolts that hold the rear part of the tank cover down.
Gecko5 is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 1:35 AM.
