f3 clutch problem
Old 10-02-2007, 5:41 PM
Bike(s): cbr600 f3 bmw steelgray
Rep: bigkeyz is on a distinguished road (10)
f3 clutch problem
I have a 96 f3 that i think i burnt the clutch last night. The bike will only start to get power in any gear when my clutch is released for like 1-2 seconds.no gradual power gain as the clutch is slowly released does anyone know how hard of a job this is I have new friction plates already i just hope thats what it is.
bigkeyz is offline
View bigkeyz's Profile View bigkeyz's Gallery Find More Posts by bigkeyz
Old 10-08-2007, 7:14 PM
Bike(s): 2001 CBR 929rr
Rep: Triax is on a distinguished road (16)
Re: f3 clutch problem
Not to hard just pull the cover off and replace them clutch fibers the same way they were taken out and put it all back in and put the cover back on.
Triax is offline
View Triax's Profile View Triax's Gallery Find More Posts by Triax
Old 10-08-2007, 9:17 PM
i did that and replaced the friction plates it was better but would slip at highrpms and then it went back to being terrible again. im at a lost
bigkeyz is offline
Old 10-09-2007, 3:49 AM
Bike(s): 01 Aprilia SL 1000 Falco & 94 600 F234i Conversion
Rep: SoCal94F2 is on a distinguished road (11)
Did you try adjusting the cable so the lever has just a little slack?
Are you running an oil additive by chance? Many of those were designed for cars which do not use a wet clutch system.
When you replaced the clutch disks where any of them stripped at the drum? Is the drum stripped in some spots?
Thats about all I can think of at the moment.
SoCal94F2 is offline
View SoCal94F2's Profile View SoCal94F2's Gallery Visit SoCal94F2's homepage! Find More Posts by SoCal94F2 My Map Location
Old 10-09-2007, 6:43 PM
the friction plates looked a little more worn then the new ones, but there was nothing that really jumped out at ya. I didnt check the drum. do you think its best to just order new plates and springs? I was just looking at a barnett kevlar kit for $129. I'd hate to buy it and not fix the problem. I also havent let slack out of the cable Im gonna try that later.
bigkeyz is offline
Old 10-13-2007, 9:43 PM
Ok I let the slack out and no good, the bike switches gears and all but it feels like im driving while holding in the clutch halfway at all times. Could something be getting stuck causing the clutch to stay engaged.
bigkeyz is offline
Old 10-14-2007, 12:31 AM
Mr. Brownstone
Bike(s): 05 600RR
Barnett clutches suck major ass. Their springs are good, but the best clutch parts are OEM. Sounds to me like you need to get a service manual and make sure the cable is actually adjusted to spec first and foremost.
Second, you have to stop using oil with friction modifiers in them like moly.
Then, get a new set of both fibers and steels from a Honda dealership and install them all correctly. Installing a set of fibers in with old steels that are worn, burned or coated with moly oil or the like will only serve to destroy the new fibers in a matter of minutes.
Did you put the one different plate in the correct position? What about the judder spring?
BDA116 is offline
Old 10-14-2007, 10:12 PM
I didnt remember seeing a different plate i thought they were all the same, i give up just gonna bring it to someone, fix, then sell it i been meaning to get a new bike anyway.
bigkeyz is offline
Old 10-14-2007, 11:32 PM
Mr. Brownstone
Bike(s): 05 600RR
Yep, on the F3 the outer disk is different from the others, must go in a certain way.
BDA116 is offline
Old 12-24-2007, 3:32 PM
Bike(s): cbr600rr, xr650l, rd400, Derbi GP1 (50cc)
Rep: sospelotudo is on a distinguished road (11)
Originally Posted by BDA116 View Post
...stop using oil with friction modifiers in them...
I just wanted to make sure that wasn't missed. It is not uncommon for people to put automotive engine oil in their bikes. Don't. Use motorcycle engine oil. That, along with poorly adjusted cables help keep us mechanics in business.
sospelotudo is offline
View sospelotudo's Profile View sospelotudo's Gallery Find More Posts by sospelotudo My Map Location
Old 07-25-2008, 2:03 PM
Bike(s): '99 CBR F4
Rep: crazythoughts is on a distinguished road (10)
I'm having the same problem with a new clutch kit still slipping. When I inspected the friction plates, I couldn't find a difference between any of the plates. What is different about the outer friction plate? I'm suspecting that the kit was not specific to my bike.
crazythoughts is offline
View crazythoughts's Profile View crazythoughts's Gallery Find More Posts by crazythoughts
Old 09-14-2008, 6:00 PM
Bike(s): 94' CBR F2 01' suzuki gs500
Rep: TX_CBRRIDER88 is on a distinguished road (10)
Send a message via Yahoo to TX_CBRRIDER88
I have no idea what the problem is with your bike, but i'm having a problem I wanted to see if anyone could help me with ? Whats happening is while my bike is cold my clutch is making a clicking sound. It goes away when you pull the clutch in. Comon sence tells me that I need to have my clutch adjusted. How hard is it to adjust a clutch on a 94' cbr f2 ?
TX_CBRRIDER88 is offline
View TX_CBRRIDER88's Profile View TX_CBRRIDER88's Gallery Visit TX_CBRRIDER88's homepage! Find More Posts by TX_CBRRIDER88
Old 07-04-2009, 4:21 PM
Bike(s): CBR 600
Rep: Rdrider7 is on a distinguished road (10)
The F3's just have a noisy clutch. your bike does not have a problem. mine does the same thing and someone calmed my nerves. just start to worry when it doesn't engage
Rdrider7 is offline
View Rdrider7's Profile View Rdrider7's Gallery Find More Posts by Rdrider7
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 10:08 AM.
