What is the best chain lube?
Old 12-15-2007, 5:21 PM
  #31
Bike(s): 01 cbr f4i- lowered,stretched, widened
Rep: bigef4i is on a distinguished road (10)
Re: What is the best chain lube?
PJ1 blue label.......it doesnt fly all over the place, stays on the chain
bigef4i is offline
View bigef4i's Profile View bigef4i's Gallery Find More Posts by bigef4i
Old 12-16-2007, 11:34 AM
  #32
Bike(s): cbr600rr
Rep: marius is on a distinguished road (22)
Originally Posted by Blade31 View Post
Castrol Chain Wax
Tottally agree as long as you put it on while the chain is hot.
marius is offline
View marius's Profile View marius's Gallery Find More Posts by marius My Map Location
Old 12-24-2007, 12:30 PM
  #33
Bike(s): cbr600rr, xr650l, rd400, Derbi GP1 (50cc)
Rep: sospelotudo is on a distinguished road (11)
Originally Posted by pmlavigne View Post
On the subject of chains- does it pay to remove the chain now and then and give it a real good soaking and cleaning? Is it a big deal to remove the chain?
On dirt bikes or bikes with non o-ring chains, it makes sense to do so. Since most sport bikes have o/x/whatever-rings nowadays and they have riveted master links, it is, imho, not very practical for most people.
At our shop we use PJ1 or Maxima (I prefer Maxima) chain waxes. This may sound like a joke, but the PJ1 lately has a leaky nozzle that lubes my hand as well as the chain. Quite annoying really. And I am not talking about just one can, but probably the last few cases we've had. Personally, I use Honda-Pro.
sospelotudo is offline
View sospelotudo's Profile View sospelotudo's Gallery Find More Posts by sospelotudo My Map Location
Old 12-24-2007, 3:54 PM
  #34
Bike(s): 3 F2s (1 Street,1race,1parts),1 xr100
Rep: kjohnson is on a distinguished road (11)
Most of these listed here are really good.I started with the HP1 and it works really well.Motul is excellent,and so is their entire product line,as are Yamaha chemicals.I just happened to start off with HP1 and it works well.
There are better ways of cleaning a chain than removing it.Here's what I do:
1.Go to a bicycle shop and get a sprocket brush.They're cheaper there.
2.Place rags underneath the chain and swingarm.Keep a few more handy.
3.Raise the rear wheel.Pitbull stands rule all others.
4.Spin the rear wheel and WD40 the chain.Hose the chain down.You want WD40 to drip off the chain.This loosens the dirt from your chain.Careful,try not to get any on the wheel.If you do,wipe it off immediately.
5.Start scrubbing the chain with the brush,chasing the brush with a rag,wiping off the excess.Do this at one foot intervals.
6.Repeat step 4 until that section of chain no longer flows dirt when being sprayed.
7. Start next section and repeat steps 4&5 until entire chain is clean.
8.Wipe down the entire chain.Make sure the chain is nice,clean and dry.
9.Wipe off the rear sprocket,swingarm and anywhere else WD40 run-off has occurred.
10.Apply your choice of chain lube.
11.Smile,and go for a ride.
kjohnson is offline
View kjohnson's Profile View kjohnson's Gallery Find More Posts by kjohnson
Old 12-24-2007, 4:28 PM
  #35
Bike(s): XRR 'tard, VFR
Rep: slickwill is a jewel in the roughslickwill is a jewel in the roughslickwill is a jewel in the rough (252)
The above post is pretty good. I'd add a couple points though. If you cut a big piece of cardboard you can slide it right behind the sprocket and it really helps keep your rim and tire clean. Also in between 9 and 10 I'd take it for a ride to get the chain heated so that your lube penetrates and sticks better.
I use WD-40 also (a subject of great debate) but I do think that kerosene is better, just less convenient, and is usually what is recommended by the chain manufacturer's.
slickwill is offline
Old 05-26-2008, 2:48 AM
  #36
Rep: 95Roguem3 is on a distinguished road (10)
Im not one to generally bump old threads, but when this is the EXACT thread I was looking for, it seemed better to just post my question here.
I recently picked up an '01 F4i and will be changing the oil/filter and lubing up the chain ASAP. Ive read good things on WebBikeWorld about "Dupont Teflon Chain Lube" and was wondering if anyone had used it or could recommend it?
I dont want the super-messy swingarm and am looking for ways to avoid that while getting maximum lubrication and longevity out of the chain. Im thinking the factory spec 80w or 90w oil is going to sling around pretty heavily.
Ive read this post and wrote down a few suggestions, but thought I might also ask about the Dupon product while Im here.
95Roguem3 is offline
View 95Roguem3's Profile View 95Roguem3's Gallery Find More Posts by 95Roguem3
Old 05-26-2008, 3:41 AM
  #37
Bike(s): 2008 CBR 1000 RR , 1982 Katana 1100, 98 KDX 250
Rep: dan.slabbert@gm is on a distinguished road (10)
Dunno the Dupont product but its bound to be good.
Forget what the factory/owners manual sez bout lubing with gear oil unless u r unable 2 get anything else or or like your bike liberally sprayed with gunk!
dan.slabbert@gm is offline
View dan.slabbert@gm's Profile View dan.slabbert@gm's Gallery Find More Posts by dan.slabbert@gm
Old 05-26-2008, 12:00 PM
  #38
Bike(s): 2007 HONDA CBR1000
Rep: bulldog12 is on a distinguished road (11)
when you get the fling off, i just use WD-40 to clean up, it comes off super easy. Also, for those who havne't, you may want to remove front sprocket cover and clean around there. i hadn't done this on my 07CBR1000, it only had 10,xxx miles on it and i didn't think it needed it. when i'd get back from a track day, or a hard day of riding, there would be stuff all over the gear shifter and all around that area. i finally took the cover off and WOW was it dirty, even found a 1" piece of hose clamp in there, that apparently couldn't work it's way out. (on my old katana750 i found a rock in there, i kept hearing a noise while riding, but when off the bike and rotating chain i didn't hear anything) the WD-40 cleaned the area nicely and to my surprise at the track I could turn quicker times, get up to speed quicker, shifting seemed to be even more smooth. definately worth the extra effort to clean, and relube. i won't wait 10,xxx miles next time.
Maxima synthetic is what i use, pretty messy though.
bulldog12 is offline
View bulldog12's Profile View bulldog12's Gallery Find More Posts by bulldog12
Old 05-26-2008, 1:14 PM
  #39
I'm a bird.. NOT a bloke!!!
LoopyLee's Avatar
Bike(s): Honda, Kawasaki
Rep: LoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond reputeLoopyLee has a reputation beyond repute (2491)
Send a message via MSN to LoopyLee Send a message via Skype™ to LoopyLee
Just fitted a Scottoiler to my baby blade.. OH swears by them.. Chain is lubricated all the time and only have to remember to top up the reservoir every so often..
LoopyLee is offline
View LoopyLee's Profile View LoopyLee's Gallery Visit LoopyLee's homepage! Find More Posts by LoopyLee
Old 05-26-2008, 1:57 PM
  #40
Bike(s): 2006 CBR1000RR
Rep: BALDGONZO is on a distinguished road (26)
Bulldog, when you took the cover off did you have to mess with the clutch slave cylinder or replace the gasket under the cover?
BALDGONZO is offline
View BALDGONZO's Profile View BALDGONZO's Gallery Find More Posts by BALDGONZO
Old 05-26-2008, 2:30 PM
  #41
Bike(s): cbr 600 f3
Rep: djer73 is on a distinguished road (14)
Castrol Chain Wax. theres nothing better.
djer73 is offline
View djer73's Profile View djer73's Gallery Find More Posts by djer73
Old 05-26-2008, 5:06 PM
  #42
Thanks guys!
The problem with the Dupont stuff is that I cant find it locally and instead would need to pay $7 shipping on a $6 can of lube. Ill either end up ordering 2 or 3 cans to offset the shipping cost or go with either Maxima or Castrol.
Thanks again.
Old 05-26-2008, 7:52 PM
  #43
Bike(s): 2000 rc51, 95 cb1000
Rep: Grover130 is on a distinguished road (11)
Lowe's carries the dupont lube.
Grover130 is offline
View Grover130's Profile View Grover130's Gallery Find More Posts by Grover130
Old 05-26-2008, 8:03 PM
  #44
No WAY! Thats awesome. I practically live there ( ) and hadnt even though to look for chain lube.
I noticed today that atleast 1 of the rear sprocket teeth is missing (well, its there but has been broken down quite a bit). Im having the CCTL replaced, and Im also going to have the chain and sprockets replaced this week.
Thanks again!
Old 05-26-2008, 9:50 PM
  #45
nope, i had to realign the clutch slave, wasn't different at all. the gasket was just a little metal thing that slid inbetween the cover and the bike. if you havn't taken it off before, leave the rear wheel on. the cover is pretty difficult to get off, but when i'd pull back on the chain it finally came off.
Old 05-27-2008, 2:45 AM
  #46
Great! A couple of questions:
  1. Does it come filled with lubricant
  2. If so what lubricant
  3. Is it refillable or throw away & replace with new
  4. If refillable, what do u use; is there a choice of products & r they easily available
  5. how long u been using it - sounds recent so maybe u dont yet no how well it works
  6. & most importantly for me, does it fling shyte all over the rear of the bike (notably the tyre!) oops sorry - tire in USA speak
Personally i use Castrol Chain Wax when i can get it here or i import it. i use the bike for work but mostly track - done 12,000 km in 2 years on the same 520 chain & sprockets (CBR600RR). Its clean & stays put & has obviously worked
Old 05-27-2008, 8:37 AM
  #47
Out Of Many, We Are One
Twincam's Avatar
Rep: Twincam has a reputation beyond reputeTwincam has a reputation beyond reputeTwincam has a reputation beyond reputeTwincam has a reputation beyond reputeTwincam has a reputation beyond reputeTwincam has a reputation beyond reputeTwincam has a reputation beyond reputeTwincam has a reputation beyond reputeTwincam has a reputation beyond reputeTwincam has a reputation beyond reputeTwincam has a reputation beyond repute (2037)
I can't give you all of the details as personally I do not own one, but the Scottoiler is a very good piece of kit to have.
Scottoiler - Automatic Chain Lubrication System
It is refillable for sure and I believe you can buy original Scottoiler Oil but am not too sure if you can use any others - Maybe LoopyLee can fill in the gaps... Well once the rain stops.
Twincam is offline
Old 06-02-2008, 3:03 AM
  #48
Ta. Slipperblock type looks good.
I live in Bahrain & encounter problems having stuff shipped here - seems u need to have an Aramex account. I normally use one of my mates in the US 5th fleet which means that the stuff comes from the US. I've noticed its generally cheaper than UK, also these guys get free shipping!
I'll contact one of my Brit mates to find out the drill.
Old 06-02-2008, 11:00 AM
  #49
Rep: tlstreak is on a distinguished road (36)
I started using silkolene Race years ago. I bought a big can and am still using the same can. I think I might actually have to buy another one soon. It has lasted like 8 years.
Its very thin, clear and does not fling like the white lithum, maxium, PJ1. I tried it and wont go back to anything else. I clean and lube my chain before I ride each weekend.
tlstreak is offline
View tlstreak's Profile View tlstreak's Gallery Find More Posts by tlstreak
Old 06-22-2009, 5:31 PM
  #50
Rep: DuPontLube is on a distinguished road (10)
I represent DuPont Performance Lubricants and if anyone has a specific question about our products, I can answer it publicly on this forum (provided the administrator allows it). The riding community has really rallied behind our chain lubes so we want to support them on this forum.
DuPontLube is offline
View DuPontLube's Profile View DuPontLube's Gallery Find More Posts by DuPontLube
Old 06-22-2009, 6:30 PM
  #51
Bike(s): Repsol 05 Blade
Rep: NorthSide is on a distinguished road (14)
WD-40 is a de-greaser. It strips the grease out of your O rings/ X rings or whatever you got. I use it to clean the side plates, but would never spray it on the O rings. Castrol chain cleaner/good scrub/quick blast to get it warm/then castrol chain wax. Job done.
Everyone seems to have their own personal favourites though, so I guess go with what you like.
Keep that WD-40 away from you bearings/brakes etc, its nasty if it gets into the wrong place!!!
NorthSide is offline
View NorthSide's Profile View NorthSide's Gallery Find More Posts by NorthSide
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 3:50 AM.
