| Re: Clanky metal sound Chain adjustment is so fun! Since there seems to be people experiencing problems, I'll write a little FYI for those who may be interested.
Points to remember:
1.Chain tension changes when you tighten the axle nut.
2.If the adjustment is good, and you need to take off the rear wheel, mark the adjusters so you don't have to spend time readjusting the chain later.
3.Adjustment should be made with the chain clean and lubed.
4.If you make an adjustment and it seems to change too quickly, check your sprockets for wear.
5.A good way to make sure the adjuster blocks are tight to the set screws is to put a rag between the chain and the rear sprocket and roll the bike to pull the axle and blocks tight before tightening the axle nut.
6.If your chain is too tight, it can mess up your countershaft and or transmission bearings. Too loose and it messes up your sprockets and could fall off and go through your case!
For those who work on their own bikes, be careful and remember: manuals and attention to detail are key! Ride safe! |
