Electrical Problem
Old 11-15-2007, 7:39 PM
Bike(s): 2001 cb4 F4i
Rep: austinlh is on a distinguished road (10)
Electrical Problem
Ok i have a 2001 cbr f4i and long story short i had to replace my right blinker and rewire it. i got it rewired and tested it and it was blinking but it was blinking fast. i was tired of messing with everything so i just started putting everything back together and was going to deal with it blinking fast. when i plugged all the connectors back in (two that go to the display, tach speedo, etc and one that goes to the front fairing headlights, blinkers, etc) after i plugged it all back in my display stuff did not work at all. the only thing that came on was the clock.
i checked everything and made sure it was plugged in good. one of the connectors when i unplugged it and plugged it back in would make the tach move all the way around like it does when you turn the key on but it would not keep working. but it did this before the connector was plugged all the way in.
so i probably have a electrical short somewhere but how can i figure out what is wrong without completely replacing everything?
austinlh is offline
View austinlh's Profile View austinlh's Gallery Find More Posts by austinlh
Old 11-16-2007, 4:03 AM
-Z-
Gearhead/Sportbike Nut
-Z-'s Avatar
Bike(s): 1999 VFR800, 2002 954
Rep: -Z- will become famous soon enough (88)
Send a message via AIM to -Z-
Re: Electrical Problem
Sorry I don't have a better answer for you man, but the first thing I would check would be all the fuses, just in case. Then I'd grab the wiring diagram from my service manual, a multimeter, and start checking all the connections. The very first ones I would check would be the electrical grounds, namely anything that connects to the frame or engine, or routes back towards the battery. A lot of times, electrical faults are caused simply by faulty grounds.
-Z- is offline
View -Z-'s Profile View -Z-'s Gallery Find More Posts by -Z- My Map Location
Old 11-16-2007, 1:06 PM
You have an electronic flasher. Its giving you a diagnostic code!
Blinking fast: burned out bulb, too low wattage, or too low current (LEDs...)
Solid, no flash: short
dattaway is offline
Old 11-16-2007, 7:18 PM
i finally figured it out. turned out to be just a blown fuse. stupid me for not checking that in the first place. and i fixed the fast flashing by rewiring the blinker. thank goodness i got it fixed i havent been able to rider for 5 days now i was starting to have withdrawls. thanks for the help anyways
austinlh is offline
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 7:45 PM.
