cbr 600 f2/f3 installing head
Old 12-04-2007, 11:43 AM
Bike(s): all jap bikes but no yamaha
Rep: jtech is on a distinguished road (10)
I believe I have a f3 motor in a f2 bike. Took my head off to check out cylinder walls and to shim valves. Everything looks good and valves are now shimmed correctly. I looked in my factory manual and there is no tightening sequence on the head bolts. It just says installation is reverse of removal. Do I tighten from the inside to the outside? Is there a sequence?
jtech is offline
View jtech's Profile View jtech's Gallery Find More Posts by jtech
Old 12-06-2007, 8:51 AM
Re: cbr 600 f2/f3 installing head
I can't believe no one knows this answer?
jtech is offline
Old 12-19-2007, 8:40 AM
Still no answer, does anyone break apart their motor these days, or does when the bike quits it goes to the scrap yard. I guess before long the dealer will not even service the bike!
jtech is offline
Old 12-24-2007, 11:19 AM
Bike(s): cbr600rr, xr650l, rd400, Derbi GP1 (50cc)
Rep: sospelotudo is on a distinguished road (11)
The dealership where I work won't service anything over ten years old. As for your question, usually things get tightened from the center outwards, if you tighten the outside first the center of the head may never compress the gasket properly. Criss-cross from the center out.
sospelotudo is offline
View sospelotudo's Profile View sospelotudo's Gallery Find More Posts by sospelotudo My Map Location
Old 12-24-2007, 12:10 PM
segiano's Avatar
Bike(s): 2007 Honda CBR1000RR & 1992 Honda CBR600F2
Rep: segiano is on a distinguished road (10)
Not sure if it is applicable to the tightening pattern for the head, but on page 8-5 of the factory manual a tightening pattern is given for the cam shaft holders. The pattern is a hybrid between center-out and out-to-center. The factory may have came up with this scheme to ensure a flat installation of the cam. Something to consider. Good luck.
segiano is offline
View segiano's Profile View segiano's Gallery Find More Posts by segiano
Old 12-28-2007, 9:24 PM
The F4 manual says to install the 9mm bolts with threads oiled/greased and tighten in a criss-cross pattern in three steps. It should be the same for the F3.
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 6:00 AM.
