12-23-2007, 5:48 PM
Bike(s): 2001 SP1 RC51, 2002 CBR 600 F4i Age: 26 Posts: 15
| that damn steering stem Rebuilding the bike form the ground up after it was in boxes, but for some reason my steering stem has alot of play as if I were to hit a pot hole there would be som serious forward backward motion. been throught the microfish, all the parts are there and I've tightened everything down as much as i could....any suggestions???  |
12-23-2007, 6:07 PM
Bike(s): '01 CBR929 Age: 49 Posts: 7,906
| Re: that damn steering stem Check the steering head bearings...they might need replacing.
12-23-2007, 10:19 PM
| Re: that damn steering stem I have checked the bearings and they seem to be in good condition. The upper or lowerspacer for the steering stem seem to not seat correctly. |
12-24-2007, 8:37 AM
Bike(s): CB750, GL1000,CBX, Blackbird, 2005 CBR 1000rr Posts: 402
Rep:  (28) Rep Power: 3
| Re: that damn steering stem Something definitely out of place JJ. Since it was apart when you got it, could a spacer plate or something be missing? Very critical area so maybe a shop manual would help. You mentioned you tightened everything down as much as you could. Should only be the one nut on the top of the stem that gets tightened to make your bearing adjustment. |
12-24-2007, 11:08 AM
Bike(s): cbr600rr, xr650l, rd400, Derbi GP1 (50cc) Posts: 112
Rep:  (11) Rep Power: 1
| Re: that damn steering stem It sounds like perhaps your races are not seated properly, however they don't usually move upon disassembly. Were they replaced? Sometimes they become misaligned during installation and trap the resultant metal shavings under themselves. Meaning they need to be removed in order to get them to ever seat right...if they are your problem. Good luck! |
12-24-2007, 10:24 PM
| Re: that damn steering stem No everything is as it should be as far as parts are concerned. The races are clean and clear of metal shavings. I can not seem to get the bottom race and bearing to move down enough to let the top get in the proper position. The top spacer s just not in the correct posiotion in the steering stem channel. |
12-24-2007, 10:35 PM
Bike(s): k6 GSXR750, 97 YZF1000, 05 600RR, 02 954 Posts: 1,244
Rep:  (29) Rep Power: 4
| Re: that damn steering stem Do you have any pics? I just did the same thing that you are doing and i think that i know what you are talkin about... But the pics would help alot. |
12-24-2007, 11:07 PM
Bike(s): 1996 900rr fireblade Posts: 269
| Re: that damn steering stem wow i am stumped! |
12-25-2007, 8:13 AM
| Re: that damn steering stem will do i'll get some pics as soon as i can too busy playing with some x mas presents for my RC51 |
