12-24-2007, 11:07 PM
Bike(s): Honda CBRF4I Age: 37 Posts: 5
| HELP HELP HELP I have had nothing but problems my Honda cbr F4i it is blowing out white smoke and leaking oil where the muffler connects at the bottom, it is also sucking so much gas. i put a full tank of in yesterday and took it just a couple of blocks down the road and let it run for about 10 minutes, and the tank was more than half gone cant even see the gas in the tank any more. Also i have no pick up the bike wont even go over 87 mph it back fires. what i have done to the bike is put new spark plugs oil change oil filter, new gas the high octane 97. i am about to give up on this bike i just cant figure it out. and now my front brake went out. there is no leak and i checked the brake fluid and it was good. so if there is any one out there that can help me please write back a.s.a.p
PLEASE PLEASE PLEASE
THANKS ROB |
12-24-2007, 11:59 PM
Bike(s): 954rr black/titanium. ktm400sx Age: 24 Posts: 363
Rep:  (11) Rep Power: 2
| Re: HELP HELP HELP did this happen all of a sudden or was the bike like this when you got it? |
12-25-2007, 12:02 AM
| Re: HELP HELP HELP happend all of a sudden |
12-25-2007, 12:03 AM
| Re: HELP HELP HELP an f4i shouldn't need 97 octane. but that wouldn't make it run this crappy either. if this happened to you all of a sudden maybe check the exhaust for blockage (sounds like a possibility). maybe some punk kid stuffed a steak in there or something. |
12-25-2007, 12:11 AM
#5 | | Abandon All Hope
Bike(s): 2000 929 Age: 37 Posts: 571
Rep:  (25) Rep Power: 2
| Re: HELP HELP HELP Seems unlikley it would all of a sudden have several unrelated issues. The smoke, oil leak and gas may be related. First is the oil leaking from the exhaust or something above and it drips on the exhaust? Smell it does it smell like gas? It could be your engine is getting over fueled and either gas is getting in the exhaust getting black and dripping out looking like oil or is getting in the case and over flowing the oil. I have seen this with bikes when the fuel cap stops venting. It fills the entire engine and exhaust with gas. Drain the oil and check it. Tip the bike up or take off the muffler and ip the bike up and see if fuel comes out. If so try running the bike with the cap open. May also be open injectors or another fuel managment problem. |
12-25-2007, 12:16 AM
Bike(s): k6 GSXR750, 97 YZF1000, 05 600RR, 02 954 Posts: 1,244
Rep:  (29) Rep Power: 4
| Re: HELP HELP HELP Quote:
Originally Posted by snw40 happend all of a sudden | All of a SUDDEN??????????  ...... So all at once you got, backfiring, oil leakage, tank of gas drinkin itself, and your brakes went out. Who did you buy the bike from? It sounds to me that there was VERY PISS POOR maintaining of this bike from the get go for all of this to happen at once. What is your tech skill when it comes to bikes? Was the oil leakin B4 you did the oil change? The speed limiting of the bike sounds like a fueling issue, possibly a breathing issue with the airbox. I would lift the tank and pay close attention to what everything looks like while doing so. Make sure there is no binding of any of the breather hoses and fuel hoses under the tank. thats just for starters. As far as the oil leaking, change that seal on the pan, or check the oil filter, make sure that the filter is hand tight and that the o ring is in good shape (should b ok if new), check that there are no cracks. that is all that i can think of for now. As far as the brakes, change the pads and post a pic of the present pads. Also make sure that there is no ait in the lines (bleed'em good).
Reason: forgot bout the brakes
12-25-2007, 12:18 AM
| Re: HELP HELP HELP ahh yes. fuel cap that stops venting makes em run pretty crappy. |
12-25-2007, 12:19 AM
| Re: HELP HELP HELP ok doom ill try those tomorrow thanks. but yes it smelike gas at the exust pipe and i checked to see if it is dripping from the top and it isnt. it is dripping right where the exust pipe conects to the pipes that comes from the engine, i forgot what its called |
12-25-2007, 12:23 AM
| Re: HELP HELP HELP thanks rocket but i have had the bike for 2 yrs now and it never did any of this stuff before. and i have kept up the maintnance on it very well. but ill check every thing again |
12-25-2007, 12:33 AM
#10 | | Abandon All Hope
| Re: HELP HELP HELP If it smells like gas do this: Remove spark plugs and either ground the wires or if its coil on plug disconnect the coils. Crank the engine till all the fuel is blown out of the cylinders. You will want to put some rags over the plug holes so gas does not shoot all over. Have someone tip bike up on its rear wheel and empty fuel out of exhaust system. Leave all this open a while so the left fuel will evaporate out. Put a small amount (1/2 tea spoon) of oil in each cylinder then put plugs back in and coils etc back on. Put exhaust back on. Drain oil and fill with new oil. Open fuel cap, start and run bike. It will smoke a little from the oil but should stop a fter a few minutes. If it runs OK and does not flood out again it is your cap. Drain the oil again refill it and change the filter. If it does reflood you may have an open injector or fuel managment issue. When you crank it watch to see if fuell comes out of ALL the cylinders or just one. If it is one it is probably an injector. If it is all 4 you have another issue. |
12-25-2007, 12:34 AM
#11 | | Abandon All Hope
| Re: HELP HELP HELP Better yet just give me the bike and buy yourself a new one :o) |
12-25-2007, 3:18 PM
Bike(s): CB750, GL1000,CBX, Blackbird, 2005 CBR 1000rr Posts: 425
Rep:  (28) Rep Power: 3
| Re: HELP HELP HELP Can't believe this. The third time in a week similar problems posted on 600's. I don't know how to search the other threads but a fuel pressure regulator is suspect. Sucking fuel through the vacuum line that's connected to it. |
12-25-2007, 5:09 PM
#13 | | Abandon All Hope
| Re: HELP HELP HELP Possible, Seen that on cars. Usually it just makes it run rich. Would have to pull a LOT of fuel through the regulator to flood out the whole engine but I can see how it coud happen. |
01-07-2008, 11:56 PM
#14 |
Bike(s): 2001 CBR 929 Posts: 124
Rep:  (10) Rep Power: 2
| Re: HELP HELP HELP So you found oil on your headers or midpipe?(the 4 pipes that go into the engine) I think it's possible that you might have melted a hole in your oil filter. Check that stuff that the mentioned above (non venting fuel cap) and locate the leak. Riding around with an oil leak is pretty bad news.
Keep us updated. |
