I have a 1996 CBR F3 that is only hitting on cylinders 3 and 4. This all started after I did a compression test, before that, the bike was running great. (Why did I have to mess with something that was working well? ... another topic) So everything was fine, I pulled the plugs, checked the compression (which was all even), then replaced the plugs and attempted to start the bike. At that point, I only had #3 and 4 generating heat.
The spark plugs, tested out of the engine, all seem to work normal on their respective wires, although they seem a little weak. (I don't have Honda experience to compare them to..) I have compression. It's getting gas, but I'm not getting power from #1 or #2. I removed the exhaust manifold, among other things, in an attempt to figure this out. Occasionally I'll get a backfire on 1 or 2, which means there's spark at some point, but at startup they will blow out unburned fuel mist.
Here are the items I've checked:
-Flipped spark plugs from the working cylinders to the dead cylinders, no change.
-Flipped ignition coils, no change. (one coil fires #1 & #3, the other fires #2 & #4, so it really shouldn't have an effect anyway, since #1 and #2 aren't hitting.)
-All resistance tests on the coils are normal, including the plug wires
-The pulse generator has normal resistance
I know cylinders 1 and 2 are getting gas, because the plugs are damp after I run the engine on the two working cylinders.
What could I have knocked while pulling the plugs that would cause this? I have unplugged and cleaned most of the wire connectors for engine management.
Is it possible that I fried the spark unit when I tested the compression? Would a wanky unit cause two cylinders to drop out but fire the other two correctly?
The past few days have been really frustrating, and I'm at a loss of how to approach this repair. I GREATLY APPRECIATE ANY IDEAS!
