1995 Honda CBR F3, Overheating ...
Old 04-23-2008, 12:15 AM
Bike(s): 1995 Honda CBR 600 F3
Rep: Absoluteg is on a distinguished road (10)
Send a message via AIM to Absoluteg Send a message via MSN to Absoluteg Send a message via Yahoo to Absoluteg
So I've recently noticed that my bike is overheating when I'm stuck in traffic or idling for a long period of time. So far I've replaced the Thermo Sensor (Which tells the gauge when its hot), and Thermostat, also the Fan Switch (When the coolant gets hot the switch grounds the circuit making the fan turn on). The Fan never turns on, even when the temp starts to rise. I'm not sure if thats normal . I will try to clean the radiator as best i can. Any suggestions on what could cause the Bike to overheat and what i could do to resolve the problem.
Absoluteg is offline
View Absoluteg's Profile View Absoluteg's Gallery Visit Absoluteg's homepage! Find More Posts by Absoluteg My Map Location
Old 04-23-2008, 12:19 AM
Rep: lanbrown is on a distinguished road (39)
Re: 1995 Honda CBR F3, Overheating ...
How is the radiator cap? Any air in the system? When was the coolant chnaged last? Did you use distilled water?
lanbrown is offline
Old 04-23-2008, 12:23 AM
The Radiator cap looks fine (but i did not test it), I did flush the system recently, but unsure of how to purse air in system (if any). I used 50/50 of a pre-mixture.
Old 04-23-2008, 12:27 AM
Make sure the cap seals properly. You might just replace the cap, the spring could keep the correct pressure from reaching. It could be 13-years old.
Make sure you do this when the engine is cold. To purge air, you need to have the engine running and just squeeze the hoses to dislodge air. Blipping the throttle can help as well.
lanbrown is offline
Old 04-23-2008, 12:32 AM
I Appreciate the advice, i will purchase a new cap, and also try the technique of blipping the throttle and squeezing the hosed to dislodge any air.
Old 04-23-2008, 12:37 AM
A cap should be $10 or so, so it is cheap to try.
lanbrown is offline
Old 04-23-2008, 4:04 PM
Its $30 from the dealership, I opted to purchase one from Auto zone for $8. I did make sure it was a 16lb cap. After replacing the cap, I did degrease the radiator. Its still Overheating !!! I cant think of anything else ...
-G-
Old 04-23-2008, 6:13 PM
If it was the thermostat, it would be stuck open. I think you have air in it then. Unless the bike is running way too lean.
lanbrown is offline
Old 04-24-2008, 12:03 AM
So how else can i bleed the system (Besides what i did previously)?
-G-
Old 04-25-2008, 12:39 AM
Rock the bike from side to side. Air can be tricky and wants to stick around.
How does the coolant look?
lanbrown is offline
Old 04-25-2008, 1:28 AM
Bike(s): yellow and blue 06 1000rr, 01 blue/white gsxr750
Rep: blue1000rr is on a distinguished road (11)
is your water pump operating like it's supposed to? also put some Water Weter or Engine Ice in it. makes it run 10-20 degrees cooler. also check the fan motor if it isnt turning on at all. mine turns on at about 202 degrees
blue1000rr is offline
View blue1000rr's Profile View blue1000rr's Gallery Find More Posts by blue1000rr
Old 04-25-2008, 8:56 AM
I've rode the bike a few hundred miles, would that be enough for the bubbles to come loose? I did replace the water pump seal about 2 months ago, the water pump looks good and seems to be working normaly. I've grounded out the fan (It turns on). When i plug it into the fan switch(in the radiator), no matter how hot it gets, the fan never turns on. The coolant was flushed about 2 months ago and looks good. I dont have a digital temp gauge, i have a analog one (which isnt that reliable). I also have some pictures posted, ill post some of the guage.
Old 05-13-2008, 2:24 PM
So ill tried the technique of bleeding the air out of the cooling system by:
Removing the radiator cap
Blipped the throttle
Replaced cap after about 1 minute.
Let bike idle till it got to normal operating temperature, then waited a few more minutes to watch the bike overheat again.
Any other ideas ?
Old 05-18-2008, 1:59 PM
Bike(s): CBR powered race car.
Rep: avendelrdp is on a distinguished road (10)
Check and see if both the inlet and outlet hoses to the radiator and getting hot. If one is not, then your water is not circulating. Could be the pump, or the thermostat. Could be an obstruction in the system.
avendelrdp is offline
View avendelrdp's Profile View avendelrdp's Gallery Find More Posts by avendelrdp
Old 05-19-2008, 1:59 PM
  #15
Bike(s): 94' Honda CBR 600 F2
Rep: jordantech02 is on a distinguished road (10)
Just wanted to make sure you checked your fuse for the fan circuit because you have not listed this in your diagnostic checks.
jordantech02 is offline
View jordantech02's Profile View jordantech02's Gallery Find More Posts by jordantech02
Old 05-23-2008, 5:52 PM
  #16
Bike(s): 94 600 F234i Conversion
Rep: SoCal94F2 is on a distinguished road (11)
All of the above are good suggestions, but If I had to guess based upon your description, I would say that the ground to your radiator is not connected. Your fan sensor switch is probably doing what it is supposed to by connecting the ground wire to the radiator, but because the radiator is rubber mounted it needs to have the ground wire from the plug attached directly to the radiator metal (usually at the fan mount). Make sure you clean that connection of all paint and such so you get a goo ground.
Worste case scenario, you could always run a wire from ground to the sensor plug - the fan will always be on when the key is on.
SoCal94F2 is offline
View SoCal94F2's Profile View SoCal94F2's Gallery Visit SoCal94F2's homepage! Find More Posts by SoCal94F2 My Map Location
Old 05-23-2008, 8:15 PM
  #17
I did check the routing of the hoses, they are correctly installed. I also check the fuse for the fan circuit and the ground(where radiator is mounted), all are good and working fine. I did ground out the fan so it stays running, the temperature would still climb to hot. The only thing i haven't checked is the actual gauge. The service manual says to ground it out and watch the gauge rise to hot (Would be nice if i knew the resistance). Ill try and get it to the shop to have a technician look at it but that would not be for a few weeks. More suggestions would be appreciated.
-G-
Old 05-23-2008, 10:17 PM
  #18
For the temp sensor next to the fan you only need 3 things to test; a boiling pot of water, a multimeter and a cooking thermometer. Bring a pot of water to 200 degrees using the thermometer, attach leads to sensor and submerge it. Bring the temp of the water up quickly. Resistance should drop move from almost open to almost shorted at around 215 degrees.
Old 05-23-2008, 11:46 PM
  #19
Thanks for the information, I've replaced that sensor. I was asking how to test the actual gauge. I did read the service manual but it does not show the testing procedures for the gauge.
Old 05-31-2008, 3:45 PM
  #20
Yesssssaaaaaa !!! So I tried to "burp" the cooling system again. Apparently it worked, my temp got up to just over half then the fan kicked in and brought it back down a bit then the fan shut off (Like it should). So Thanks Again for everyone's support and advise, I appreciate it. Now ill be riding as much as possible.
-G-
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 2:36 AM.
