Engine problem on my 2001 F4i
Old 06-21-2008, 6:57 PM
Bike(s): cbr600 f4i 01
Rep: unreal_civic is on a distinguished road (10)
i dont know if this is normal or not, but wen my bike is going at idle speed. ( when no throttle is added the the clutch is fully engaged) it gots at 10km/h and the engine is very jittery and the ride is not smooth. thats the main concern that the engine is like stuttering. how can i fix this or this is normal for my bike?? any help would be greatly appreactiated thanks!
unreal_civic is offline
View unreal_civic's Profile View unreal_civic's Gallery Find More Posts by unreal_civic
Old 06-21-2008, 7:47 PM
Not Normal....
Desert Blade's Avatar
Bike(s): 2006 CBR1000RR
Rep: Desert Blade is on a distinguished road (38)
Re: Engine problem on my 2001 F4i
So the bike is stopped and in neutral doing this? Or only when riding at a steady speed? Its an FI bike so I would think that there would be some sort of code or warning light. Is it making any funny noises or just being "jolty"? It could be a simple missfire from a bad plug. Hows its power and smoothness through acceleration?
Desert Blade is offline
View Desert Blade's Profile View Desert Blade's Gallery Find More Posts by Desert Blade
Old 06-21-2008, 8:35 PM
thanks for the reply desert blade. the bike does this wen its moving without any acceleration. it makes funny noise and is being being jolty. wen i accelerate though, its smooth and normal.
Old 06-21-2008, 9:34 PM
Not Normal....
Hmmm........what kind of noise? Knocking sounds, whining? And now warning lights or codes?
Old 06-22-2008, 2:32 PM
Bike(s): cbr600fh and aprillia rs50 till im 17
Rep: dontknow17 is on a distinguished road (10)
Send a message via AIM to dontknow17 Send a message via MSN to dontknow17
hi ive got a very similar problem on my 600f, she just wont rev up very quickly, shes irrisponsive, sluggish and only appears to be running on 2 cylinders.
checked; plugs, HT leads, Jets, fuel lines, compression and all seems to be fine but im starting to get iritated when 2 strokers overtake me on the dual carriageway
dontknow17 is offline
View dontknow17's Profile View dontknow17's Gallery Find More Posts by dontknow17
Old 06-23-2008, 4:50 AM
its making normal engine noises but its not consistant, its like du..du..du..du. not warning or lights go on.
Old 06-23-2008, 3:13 PM
ive solved the problem now,
check the plug leads -
igntion coil on the left should feed cylinders 2 and 3, and the ignition coil on the right should feed cylinders 1 and 4. that was what put mine out, ive set em up correctly now and she runs like a beauty.
hope this helps
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 5:06 PM.
