'02 F4i won't start???
Old 06-23-2008, 8:07 PM
Rep: brider is on a distinguished road (10)
Ok, here's an odd problem.
I changed the oil on my '02 F4i Saturday. Bike was running fine, in fact, I let the engine warm up for a few minutes before I changed the oil and filter. The official service manual says that if you change both the oil and filter, you need to put in 3.5 liters of oil. Now, I didn't check the oil level window, but I don't remember seeing where the level of the oil prior to the change. I put in 4 32 oz or .946 liter bottles of oil. This is more than the 3.5 liters required. (3.784 to be exact...)
Once I tightened everything up, I looked at the oil level window and NOTHING. I thought, WTF, that's odd? But I'll see what it looks like after I let it run for a few minutes.
And the bike wouldn't start. I killed the freaken battery trying to get it to start! Let it charge all day Sunday and just tried it again. NO LUCK!
The oil light came on while trying to start it, but I figured that was normal until oil got pumped into the new filter.
Any thoughts on what's wrong?
TIA!
--Brad
brider is offline
View brider's Profile View brider's Gallery Find More Posts by brider
Old 06-23-2008, 8:11 PM
Red Rider's Avatar
Bike(s): '01 CBR929
Rep: Red Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to beholdRed Rider is a splendid one to behold (799)
Re: '02 F4i won't start???
How are you checking the oil...on the sidestand or holding the bike upright?
Red Rider is offline
Old 06-23-2008, 8:14 PM
Thanks for the quick reply RedRider!
It's on the side stand. I hadn't thought of that...
However, I put in more than the required amount of oil, so I would think that I would be good there???
brider is offline
Old 06-23-2008, 9:36 PM
Red Rider's Avatar
Bike(s): '01 CBR929
The oil amount should be more than enough but you still need to check the level. You sure you installed the correct filter? The bike not starting may not be related to the oil change.
Old 06-23-2008, 9:47 PM
Rep: 00vfr is on a distinguished road (10)
Mine did something similar and it turned out to be the kill switch. Mine would crank and crank but never fire.I flipped the switch back and forth several times and it fired back up.I only tried this because I have had several Hondas do it to me before,my VFR was the worst. My F4i always takes almost 4 quarts to fill it.And I check it with the bike level.
Hope this helps
00vfr is offline
View 00vfr's Profile View 00vfr's Gallery Find More Posts by 00vfr
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 5:00 PM.
