HELP!!!!!!! 94 f2
Old 06-27-2008, 9:53 PM
Bike(s): 94 f2
Rep: coolname21 is on a distinguished road (10)
HELP!!!!!!! 94 f2
Ok so I need a little help with my 94 f2. The darn thing won't start! When i turn the key all my lights turn on and everything but when I go to start the bike i get absolutely nothing. I tried checking the fuses for the starter and everything seemed fine with them. I have all of my fluids to include gas and the bike is in nuetral when attempting to start. I have not checked the battery yet because my multimeter is at work and I just left there when the problem occured. Everything was running fine when I stopped and then when I tried to start the bike again I had nothing. If you guys could help me with any suggestions about this I would really appreciate it. Thanks in advance!!!!!
coolname21 is offline
View coolname21's Profile View coolname21's Gallery Find More Posts by coolname21
Old 06-27-2008, 10:23 PM
Bike(s): 95 CBR600F3, 98HD XL1200, 1981 CB650C
Rep: j_cycles is on a distinguished road (10)
Re: HELP!!!!!!! 94 f2
Try your bank angle sensor. and replace your 30amp main fuse. has worked for me.
j_cycles is offline
View j_cycles's Profile View j_cycles's Gallery Visit j_cycles's homepage! Find More Posts by j_cycles
Old 07-02-2008, 2:31 PM
Bike(s): 93 Honda CBR 600 F2, Modded to 97 F3
Rep: Jok3r is on a distinguished road (10)
Your starter is more than likely junk. I just went through the same crap with my F2. The bendex (not sure if thats the right spelling) spring inside the starter gets stuck and doesnt work right after a while. Hope this helps...
Jok3r is offline
View Jok3r's Profile View Jok3r's Gallery Find More Posts by Jok3r
Old 07-02-2008, 3:15 PM
Bike(s): 01 Aprilia SL 1000 Falco & 94 600 F234i Conversion
Rep: SoCal94F2 is on a distinguished road (11)
Sounds like a dead/dying battery. Do a charging diagnosis. These bikes are common for Reg/Rect issues which frequently result in problems like this.
SoCal94F2 is offline
View SoCal94F2's Profile View SoCal94F2's Gallery Visit SoCal94F2's homepage! Find More Posts by SoCal94F2 My Map Location
Old 07-07-2008, 12:34 AM
Bike(s): 94 f2
Thank you for all the input you guys gave it really did help alot. Being new to the whole motorcycle world its nice to know that there are people out there willing to help. Come to find out it was the battery that was the culprit. Put a new one in and away I went. Thanks again!!!!!!!
Old 07-07-2008, 1:38 AM
Dont discount the Reg/rect as causing you battery problem. A new battery may seem to cure the problem initially, but a bad reg/rect will make it return at the worst time - sometimes overcharging and causing the battery to explode. Keep an eye out for a hotter than usual seat, smell of sulfer or leaking battery. Stock rect/regs are junk and frequently fail. The Japanese TourMax brand makes an excellent unit with a big all metal heat sink at about $100. Easily spotted by the black box with red logo on it, resold everywhere under different names with the log partially obscured like this one bottom right:
eBay Motors: Hi Performance Regulator Rectifier CBR 600 900 F2 F3 F4 (item 110268254272 end time Jul-13-08 10:51:28 PDT)
Old 07-07-2008, 1:59 AM
Bike(s): '06 1000RR, '92 600F2
Rep: Weasle1000RR is on a distinguished road (11)
Stator
Weasle1000RR is offline
View Weasle1000RR's Profile View Weasle1000RR's Gallery Find More Posts by Weasle1000RR
Best viewed at a resolution of 1024x768 or higher. SEO by vBSEO ©2007, Crawlability, Inc. All times are GMT -4. The time now is 6:09 PM.
